transmission leak
Old Oct 23, 2011 | 03:19 PM
lostrider06's Avatar
lostrider06
Default transmission leak
Have developed a small leak were the transmission an moor bolt together just behind the rear jug. Its an 05 RK with about 30,000 miles. just wondering if this is a common problem
Old Oct 23, 2011 | 05:27 PM
MareRider's Avatar
MareRider
Check the exhaust pipe bracket bolts. They are also the bottom bolts for the transmission right side.
Old Oct 23, 2011 | 07:34 PM
Mikekoz13's Avatar
Mikekoz13
Check what MareRider said. That was the exact source of my transmission leak a month or so back. Tough to see, even a little tougher to get to.
The bottom two bolts had come loose. A very small socket wrench with a small hex bit and two minutes later the leak was fixed.
Old Oct 23, 2011 | 08:56 PM
lostrider06
thanks for the reply guys not sure if i know were you talking about. can you post a pic of the bolts your referring to. thanks in advance
Old Oct 23, 2011 | 09:37 PM
run1fsr's Avatar
run1fsr
Could be your trans shaft seal (PITA to replace). Overfilling your your trans fluid can also cause what appears to be a leak.
Old Oct 23, 2011 | 10:59 PM
MareRider's Avatar
MareRider
2 of the bolts are in the exhaust bracket that's below the clutch relase cover. Arrow points to the area.
Old Oct 23, 2011 | 11:05 PM
fabrik8r's Avatar
fabrik8r
Are you running synthetic? I tried synthetic for an experiment and I now have moisture at the same area you are talking about.
Old Oct 24, 2011 | 06:36 PM
lostrider06
Thanks for all the info guys. Decided to go talk to a local harley machanic today he told me that the leak was more than likely coming from were the jug an motor block gasket is an enless it got worse than it was that it was ok to keep riding.
Old Oct 24, 2011 | 06:51 PM
fabrik8r's Avatar
fabrik8r
You might be better off showing your local harley mechanic what you are talking about. Your cylinder to case seal is an oring not likely to just start leaking. Is there moisture around the bottom of your rear cylinder or moisture at the seam where the back of the engine case meets the front of the trans case? Either way I still agree to keep riding.
beary
Sep 21, 2018 02:45 PM
ronherman
Sep 3, 2013 07:31 PM
PLEIKU69
Dec 4, 2011 04:39 PM
03dragonRK
Sep 14, 2011 02:34 PM
al baehr
Aug 30, 2010 08:13 PM
