Another XM question?
Old Jul 18, 2005 | 09:50 AM
Vetter's Avatar
Vetter
Default Another XM question?
I just installed my XM reciever on my 2004 Road Glide. I initially had it on the fairing, but didn't like the placement, having to reach to change channels. Now I have it on the tank console, I made a brkt out of 1/8" steel, and it works very well. I routed the cables under the tank, but now I get alot of interference with the ignition, almost sounds like a second motor on the bike, when the RPM's are above 2000, below that, it's not bad. I also installed the Hogtunes, and they sound awesome!!!!!! I just need to get rid of the ignition interference, any ideas what can be done???
Old Jul 18, 2005 | 10:28 AM
luvmyflhtcui's Avatar
luvmyflhtcui
Default RE: Another XM question?
Your interferance is coming from all of the ignition wiring that runs under the tank to the module under the seat. The only way that you can get rid of the noise is to shield all of the wiring for your xm receiver. Go to any quality electronics retailer in your area and tell them you need some wire mess tape. It comes in a roll and it flat. You can wrap your wiring in that tape and then cover it with either heat shrink or convoluted tubing (black tubing like what's on the rest of the bike) and that should clear up the noise. You did not notice it in the fairing as there are no ignition wires up there to cause any problems. The wire mess tape is flat and in a roll and looks like screen wire only very pliable and easy to wrap around a wire bundle. If you need me to find you a retailer I will. Just send me an emial.
Good Luck
[IMG]local://upfiles/494/83F6019A2C3F4235BEB875E493B42F35.jpg[/IMG]
Old Jul 18, 2005 | 11:03 AM
nascardriver's Avatar
nascardriver
Go to www.xmfanstore.com they have what they call a noise decoupler, I used this on mine and it works great....
Harleynoob
Electrical/Lighting/Alarm
May 27, 2015 05:12 AM
Chells93
Apr 20, 2015 04:15 PM
Brian_Reale
Apr 3, 2015 07:31 AM
Mkxlng63
Mar 14, 2013 10:16 PM
zenwarrior
May 21, 2007 05:23 PM
