Flywheel shifting???
Old Oct 30, 2011 | 10:28 AM
thepun1sher's Avatar
thepun1sher
Default Flywheel shifting???
Has anyone ever heard of this I took my 08 street glide in for 510 cams and other upgrades and the tech calls me and tells me that my bottm end is shot and I need 7 grand to fix!!! I went in and the tolerances are within Harley and S&S spec But he doest see it that way can someone on here help with this.... He also said that the motor wouldnt last 5 more days but he didnt say that 2 days before when he had it reved up to 6 grand tuning it
Old Oct 30, 2011 | 10:40 AM
1flhtk4me's Avatar
1flhtk4me
$7,000 could easily buy a new stock motor.
Crankshaft runout can be alot,this is why cam chains are used.
Is the tech wanting to go with gear drive cams?If thats the case,then the crank run out has to be acceptable and the new stock run out tolerance will not work.
If the crank run out is within factory spec,theres no reason why the cases have to be split to have the crankshaft trued.Just have to use the right parts.
Lots of members here have swapped out cams without having to do major engine work.
Old Oct 30, 2011 | 11:50 AM
BadBagger08's Avatar
BadBagger08
If the crank is way out the oil pump internals and the crank spindle should show some sign of wear. If every thing is in speck I would pull my bike out of there and go else where.
I beat the hell out of mine and the last I checked it was .002 when I replaced my broken oil pump this summer.
Old Oct 30, 2011 | 01:51 PM
thepun1sher
Well he said something like .010 thousanths and thats within harley and S&S spec so I told him just to go with chain drivin 510 cams instead of the gear drivin
Old Nov 2, 2011 | 07:55 PM
thepun1sher
well finally done we went with 551 chain drivin cams and I love the way this bike rides and sounds!!
Old Nov 2, 2011 | 08:19 PM
caspr2's Avatar
caspr2
Glad everything worked out for you.
Patch
Jun 13, 2021 07:08 AM
Biker Boy 53
Engine Mechanical Topics
Sep 7, 2015 12:45 PM
LOCAL12OP
Exhaust System Topics
Feb 1, 2012 12:19 PM
shekmark
Aug 7, 2008 02:32 PM
kurtzimmi
Apr 19, 2007 05:35 PM
