Another vote for the power duals. Don't forget to look at the V&H's 4.5" TwinSlash Monster Ovals, awesome look and sound.
+1 on the V&H TS Ovals. I had those up until this winter. Sounded perfect. Just wouldn't fit under my stretched bags and fender so I had to swap out. Great product though.
Edit...Oops, you said Twin Slash MONSTER Ovals. I had the regular Twin Slash Ovals. Not as quiet as the Monster variety.
if you're not opposed to 2 into 1's i highly suggest the standard vance & hines pro pipe. the 2 into 1 exhaust systems develop more torque than any other design throughout the rev range. i wouldn't go back to twice pipes now that i have the 2 into 1. the 2 into 1 vance and hines high flow don't work as well on a 96 or 103 because the high flow reduces the velocity of the exhaust pulses thereby reducing the torque. the hf pro pipe is for much bigger motors that can take advantage of the increased flow. it comes down to bernoullis principle where a larger diameter pipe will flow more, but at slower a slower speed, and our motors depend on port velocity.
i dont see how one would really feel the differance of the TD's vs the PD's.. yes they sound slighly different with same type of slip ons.. but i think the sound is what makes u think ure going faster... the X pipe is known to give slightly higher TQ and HP vs TD's.. same for automotive... as for looks.. i like the Power Duals.. not many seen here...
ride safe...
I went with the V&H Power Duals and I couldn't be happier! There is a definite increase in performance that you can feel out the gate. Here is a pic for you to see the setup up close.
Hey trackadaptor I originally ran the Power Duals with the Slip-On's without any aftermarket air cleaner or tuner. I was getting some pretty bad vibrations at idle and even while cruising.
I had purchased the Arlen Ness Big Sucker stage 1 Air Cleaner although I had not gotten around to installing it. I installed it this past weekend and immediately took it down to the dealer for the H-D Stage 1 download.
Man did this make everything so much better! The bike vibrates far less at idle (never eliminated, these are touring bikes afterall) and it's almost smooth as glass while cruising down the road.
So that was a LONNNNNNNG answer to your question! I didn't do any sort of tuner only the H-D "approved" Stage 1 download. This is far enough for me.
If I ever feel the need to spend another thousand I will do some cams, SE Race Tuner and have it Dyno Tuned. I seriously considered doing a PC-V although I don't want to risk any potential warranty issues being blamed back on it.
