Headlight bulb?
Old Nov 2, 2011 | 10:50 AM
monkey sammich's Avatar
monkey sammich
Default Headlight bulb?
Is it HD specific or can it be bought anywhere? My low beam bulb is dead.
'01 Ultra
Old Nov 2, 2011 | 10:56 AM
mkguitar's Avatar
mkguitar
autozone etc.
think about a silverstar or other premium bulb--- but be aware that the "best" bulb in the line has a shorter service life, there is a little chart on the package
some States it's legal to use high beam in the day--- evens out the wear between low and high
mike
Old Nov 2, 2011 | 11:51 AM
StreetGlidinFreak's Avatar
StreetGlidinFreak
It's an H-4 bulb. Any parts house has H-4.
Old Nov 2, 2011 | 02:15 PM
103 sedona orange's Avatar
103 sedona orange
Check www.danielsternlighting.com He's the man!!! read about the blue tint on bulbs.
Old Nov 2, 2011 | 02:27 PM
pslarosa's Avatar
pslarosa
I use an H-4 bulb that's 65w/100w, their used on dirt/street bikes. pretty cheep, and lots of light on HI.
Old Nov 2, 2011 | 03:38 PM
Denver Dave's Avatar
Denver Dave
You may want to consider going from the sealed one piece unit to a 2 piece (bulb and lens) unit. You will find your lighting will be much improved. I recommend susquehanna motorsports - find them at www.rallylights.com. I went with the Hella brand HL79562 7" lens paired with the Osram 70H/65L H4 bulb. Huge difference.
Old Nov 2, 2011 | 03:46 PM
jpglide's Avatar
jpglide
I would look at upgrading if you're already gonna replace. Search the forums for posts on bulbs - I took user "iClick" 's advice and went with the setup below:
MUCH brighter than stock, and a lot cheaper than LED...
http://www.rallylights.com/detail.aspx?ID=271
http://www.rallylights.com/detail.aspx?ID=350
Old Nov 2, 2011 | 03:52 PM
PopsHD's Avatar
PopsHD
Try a PIAA bulb. It's tons better and brighter than the stock bulb. Chances are your local moco or indy carries them.
http://www.piaa.com/Bulbs/Bulbs-H4.html
Old Nov 2, 2011 | 04:22 PM
bmaier's Avatar
bmaier
Im running the Hella E code housing for $30 and the Osram 80/100 bulb for $12. like stated earlier, huge difference
Old Nov 2, 2011 | 04:27 PM
Iceman24's Avatar
Iceman24
http://www.germanautoparts.com/Hardware/Bulbs/H4
4th one down (Osram H4 80/100) - you'll be amazed at how bright this bulb is...
