Oil Gage Mod
Old Nov 8, 2011 | 08:41 PM
Eric Moore's Avatar
Eric Moore
just incase some may have the dip stick temp guage... I have both... I had the dip stick guage 1st... the return oil enters the oil tank near the rear of the tank... this reading will be about 20+ degrees higher than the temp sending unit mounted in the front of the oil tank for the fairing mounted gauge.......
Old Nov 8, 2011 | 09:09 PM
2black1s's Avatar
2black1s
Originally Posted by jimski
I sure hope their oil temp gauge is more accurate than their air temp gauge....
Even if it is accurate, how the hell do you read it?
I hate gauges with non-linear scales. And besides the non-linear scale, just to add a little more confusion, what do the 4 dots on the lower portion of the scale represent?
Unless of course they furnish a legend with the gauge that tells you what each division, and dot, represents. Do they? I don't think so.
Old Nov 9, 2011 | 10:40 AM
casique's Avatar
casique
Originally Posted by frenchbiker
The heat management system (EITMS) uses the front cylinder head temp, not the oil temp and a 30F to 50F difference between the 2 is normal.
What kind of oil do you use in your engine? Do you have an oil cooler?
By the way, the EITMS kicks-in at 285F.
I have FLHX with the powerpack, so yes it has an oil cooler and I use Mobil 1, 20w-50 V-twin.
thanks
gonpce
May 17, 2013 07:45 AM
Delta
May 13, 2013 10:33 AM
Vinny133
Oil Archive (no new posts)
Oct 10, 2008 08:45 PM
cubcake1
Oct 9, 2007 07:26 PM
daharleyrdr
Sep 19, 2006 05:07 PM
