Some problems with abs
Old Nov 18, 2011 | 12:00 PM
Falco's Avatar
Falco
6th Gear
Default Some problems with abs
My 2011 Ultra Limited.
Often I have problems braking on rough roads due to a disengagement of ABS. It also happens to you or is just a defect of mine?
Old Nov 18, 2011 | 12:05 PM
petewerner's Avatar
petewerner
Huh? Could u try describe the problem more completely and with some details perhaps someone with ABS knowledge will try and help u.
Old Nov 18, 2011 | 12:07 PM
rkoivisto's Avatar
rkoivisto
Default Abs
It's doing what it's supposed to do. On rough roads the wheel will become unloaded when hitting bumps. When it becomes unloaded, the brake will lock the wheel up momentarily. The ABS will respond to that.
Ignore the ABS and just keep stepping on the brake.
Old Nov 18, 2011 | 12:09 PM
wjl24's Avatar
wjl24
It's definitely a strange feeling when that happens. But as said, it's just doing it's job. Takes a little getting used to. My first reaction was to let off and re-apply brakes but that's not what you are supposed to do. Just keep the pressure on and let them do their thing.
Old Nov 18, 2011 | 12:12 PM
Geoff's Avatar
Geoff
Would be nice if Harley included an ABS on/off switch.
Old Nov 18, 2011 | 12:16 PM
av ultra's Avatar
av ultra
My rear tire does the same thing, imop way too touchy.
sgdiesel's Avatar
sgdiesel
Agreed, ABS is really not suited to this kind of riding. As stated - ignore it. It does suggest that perhaps you are riding a bit quickly over that section - I guess it is a section you know well and ride regularly.
Not a lot you can do about it really
Old Nov 18, 2011 | 12:34 PM
blarg's Avatar
blarg
yeah...except you only need ABS when you don't expect to need it.
Old Nov 18, 2011 | 12:36 PM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Try a quick start on dry asphalt and as soon as you get moving you immediately apply the brakes for an emergency braking situation. You're almost certain to hit the vehicle in front of you if you've not yet travelled one yard. Time seems to stop when you're applying the brakes and you don't know what's making the ABS hang at such a slow speed.
Old Nov 18, 2011 | 12:40 PM
sgdiesel's Avatar
sgdiesel
Yes, that would make sense - although imagine the litigation risk. In today's crazy world I am sure someone could prove that HD were negligent for not somehow figuring a way to force the rider to switch it back on etc etc etc
