Low Idle
Old Dec 3, 2006 | 03:07 PM
RonH's Avatar
RonH
Default Low Idle
Just put on the FullSac true duals and a cover insert on the air filter instead of the football. After doing that the bike runs terrific, but once warmed up the idle is about 100 rpm slow (900), which really makes my 103 shake like crazy. Any idea what during that install would make the idle drop?
THANKS
Old Dec 3, 2006 | 03:13 PM
Phrogman's Avatar
Phrogman
Default RE: Low Idle
I had a problem with my '06 Street Glide after installing the Stage I and Vance & Hines True Duals with Oval slip-ons. The problem I had was that the motor would get too hot, too fast and bring the idle down due to the EFI trying to compensate.
To fix the problem, my dealership wound up having to install the 25 degree injectors. Since then I've had no problems. Check with your dealer and find out if your bike has the 8 degree or 25 degree.
Old Dec 3, 2006 | 06:10 PM
RonH's Avatar
RonH
Thanks - I'm pretty sure I have the 25's, just from the build date is nothing else. Any other clues?
Old Dec 3, 2006 | 06:47 PM
Bryan TTM's Avatar
Bryan TTM
i like mine to idle low...with the cam it now lopes like a carb bike...to answer your question, got no idear man
Old Dec 3, 2006 | 10:05 PM
GliderXXX's Avatar
GliderXXX
ORIGINAL: RonH
What is the cutoff build date on 06 SG's if you don't mind? Where do you determine the build date on the bike?
Thanks
Old Dec 3, 2006 | 11:49 PM
dgriffith's Avatar
dgriffith
On my ultra it does the same thing occasionally, maybe once a month while riding. I,ve gotten use to it. my 02 truck does the same thing once in a while.
Old Dec 4, 2006 | 12:34 AM
SteveO's Avatar
SteveO
Try a new set of stock spark plugs, you will be amazed at the difference including a slightly higher smoother idle!
Steve
Old Dec 4, 2006 | 12:39 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Did you re-tune the PC.... Seeing as the exhaust dynamics and air intake restriction have changed.......
Old Dec 4, 2006 | 12:47 AM
RonH's Avatar
RonH
Installed the PC after the changes, so I'll take her in for a dyno soon and get everything dialed in.
pandamonium
Milwaukee Eight (M8)
15
Dec 23, 2018 06:48 AM
73shovel rider
Apr 19, 2014 11:17 AM
Killerman#1
Apr 3, 2014 07:50 PM
halfbreed
Jun 8, 2009 08:04 AM
skratch
Jun 3, 2009 03:03 PM
