soft lowers for crash bar
Old Nov 24, 2011 | 12:53 PM
speedwaysteve's Avatar
speedwaysteve
Default soft lowers for crash bar
Lookin to see if any one makes a soft crash bar lower that could be used in warmer weather.the ones i saw say not to be used in above 50 degrees
Old Nov 24, 2011 | 01:25 PM
mkguitar's Avatar
mkguitar
the soft lowers block cooling air from the motor- which is why the restriction on use. as they push through the air, they just make a big mess of turbulence which spills over the sides
hard lowers order the air flow to the motor and increase cooling ( in PHX I get oil temps 25ş cooler with the hard lowers on).
You could get soft lowers and just throw them in the saddlebags when the temps rise, I have a Pal who puts them on for the morning ride to work, takes them off for the ride home in the aft.
The H-D ones also have a cut out for hiway pegs if you use them
mike
Old Nov 24, 2011 | 01:30 PM
speedwaysteve
Tks mike,the bigggest thing is rain for me,with no lowers the rain kicks up right at your feet.too bad someone can make a soft lower thats vented for engine cooling
Old Nov 24, 2011 | 01:34 PM
Ronp42's Avatar
Ronp42
Account Retired
I have a pair of the HD soft lower's I keep in my saddle bag. If it start's raining or turns a little too cold, I'll put them on. Only takes a couple min's to put on or take off.
Old Nov 24, 2011 | 01:37 PM
Ronp42's Avatar
Ronp42
Account Retired
HD also makes Rain Gaiter's. They are easy to slipon to keep your feet dry.
Big Blue Electra
May 3, 2014 12:51 AM
EdandGrace
Oct 1, 2013 09:09 PM
david christopher
Jul 4, 2011 09:08 PM
Tek74
Mar 6, 2011 10:23 PM
r8rs4lf
Jan 4, 2009 09:07 AM
