best tuner
Old Nov 27, 2011 | 02:53 PM
XARAN's Avatar
XARAN
Originally Posted by buggy
I am using the s.e.r.t. and am happy with it. I stuck with the moco simply because warranty and 3 buddys had power commander issues with the tuner and the autotuner. Thats my opinion, one of many you will get.
Unless your using the "Street Tuner" you have voided your warranty the same as the rest of us using any other tuner, if their is a problem directly related to the tuner.
HD makes it very clear in their parts catalog what voids the warranty and most of the SE parts do, they are marked with a checkered flag
IMO most of the high end tuners (SERT, SEPST ,TTS,PV,Direct LInk, etc) are great and accomplish the same thing in the end. A lot of what to look for is if you are going to have the bike dynoed and have someone else tune it , what are they comfortable with using? Its important that the tuner is knowledgable using the product that you buy. If your going to do the tune or use a canned MAP or self tune that the product may be the one for you. I think its very important to do some research and before buying and know what you are getting into and what you expect for results.
Ive used the
Fuelpak-super easy install, worked ok for stage 1 but no ability to dyno or make changes outside of what parameters V & H send you. Also on the new bikes it eliminates the O2 sensors and is a piggyback unit
PClll- can be dynoed, I had great luck with Fuel Moto and their canned MAPS, but also a piggy back unit and eliminates the O2 sensors
SERT- very good results but I had to have the bike dynoed at a $ 400 cost, at the time it did not have the self tune that I believe the new SESPT has.
Now I am using the Power Vision with a Fuel Moto MAP and the bike is great, Im going to play with some of the data loging features and see if I can improve on the MAP that Jamie sent me. What I like best about the PV is ease of use, the self contained screen that allows you to monitor , code reset, data log etc. The PV also seems very user friendly and Fuel Moto is always helpful with support. I thin at this time the only downside is not a lot of tuners are using the product so if you wanted to get the bike dynotuned it might be harder. But that is not on my list.
Old Nov 27, 2011 | 02:58 PM
harleymike77's Avatar
harleymike77
Another one here for the TTS Mastertune.......
Old Nov 27, 2011 | 03:03 PM
Lonewolf176's Avatar
Lonewolf176
Originally Posted by 1320str8_liner
So do you need the laptop with the SERT the same as with the TTS, or is there a difference?
Are you confusing the SERT with the SESPT? The SERT is ownded by TTS and is no longer made. The SESPT is made by SPX Kent Moore. The SESPT does not require the laptop for data collection, but has enough other issues that the TTS is still out front.
Old Nov 27, 2011 | 03:07 PM
coolerman69's Avatar
coolerman69
Never seen a bad report on the SERT, I have 2 of them. PCs used to be the favorite around here but several people had problems so they kinda went away.
PistonPuller's Avatar
PistonPuller
I have the se race tuner. You only need a computer while in the garage downloading the collected data and reflashing the ecm. I cannot speak about the other tuners, but I have no problem using the tuner and smart tune function. I am by no means and expert, so if I can use, it anyone can
Old Nov 27, 2011 | 03:16 PM
Indianspringsaz's Avatar
Indianspringsaz
I had the SERT, sent it to TTS and had it upgraded. Nice tool to tune your bike. If you aren't using a dyno, just put your laptop in a small backpack. Not a big deal.
Old Nov 27, 2011 | 04:08 PM
Bill03E's Avatar
Bill03E
Doesn't matter what the "best tuner" is , it matters what the guy who is tuning likes.
Old Nov 27, 2011 | 04:29 PM
Indianspringsaz
Some truth to it. A good tuner and a TTS is hard to beat.
Old Nov 27, 2011 | 04:41 PM
trekez2's Avatar
trekez2
I'm another happy Power Commander V customer from Fuel Moto. Jamie and company are very helpful and knowledgable. I use the MAP provided and it runs great!
Old Nov 27, 2011 | 05:16 PM
FLHTCU2007Ken's Avatar
FLHTCU2007Ken
They're not cheap! I'm looking at the Thunder MAX EFI module. $900.00
It replaces the factory ECM. Easy install, more power, better throttle response, cooler engine, idle control and adjustable rev limiter, HUGH base map library included and it's the only one you ever need (per the manufacturer.)
New exhaust, cams, add inches, nitrous... supposedly it can handle it AND no dynos required.
check 'em out:
http://www.thunder-max.com
Good luck,
Ken
