Converting from 2-1 to 2-2 - 2010 SG
Old Nov 29, 2011 | 02:55 PM
KutenFLHX's Avatar
KutenFLHX
I went with 2-1-2 duals for my 2010 SG. I have Vance & Hines power duals head pipe and 4" Rhinehart mufflers. Love the deep sound of the 4" pipes and have more power with the setup (and much less heat without the cat).
Old Nov 29, 2011 | 03:11 PM
Tinman265's Avatar
Tinman265
I also have all the clamps and mounting brackets that came with the OEM 2011 touring exhaust system..........
If you do a fuel moto headpipe you would need the stock sheilds for the 2-1-2 but most companies supply everything you need to fit their system. Pipes, brackets, clamps, and sheilds. You usually just need to pick up new exhaust gaskets.
I did the Python true dual system and as an added benifit the mounting bracket acts as a heat sheild for the rear brake light switch.... who knew.....
Old Nov 29, 2011 | 03:47 PM
skratch's Avatar
skratch
if you do the fuelmoto 2-1-2, then you'll also need the crossover pipe, in addition to the heatshields.
Old Nov 29, 2011 | 05:09 PM
Tinman265's Avatar
Tinman265
Ah yes...... I forgot about that....... Good Catch....
That is about the only reason I did not go with the fuel moto set up...... Just don't like the squished crossover pipe....
Old Dec 1, 2011 | 09:02 PM
5W0P3's Avatar
5W0P3
I picked up a brand new in the box V&H hi output slip on. Sounds great! I'll post pics when I get home. Still a 2-1 system though but for $180 I couldn't argue!
Old Dec 5, 2011 | 02:51 PM
5W0P3's Avatar
5W0P3
Damnit. Now i just read a thread about gutting the cat on the 2-1-2 systems. Found a '12 2-1-2 header for $50. Wish i had kinda waited now.
My Fix
Touring Parts
21
Jul 1, 2011 03:07 AM
leohd
Dec 16, 2010 06:52 AM
All Aces
Touring Parts
Nov 24, 2010 10:45 PM
Professor
Aug 14, 2010 09:45 AM
Gizmo83
Jan 29, 2010 07:08 PM
