Accessory jack cable from Tourpak
Old Dec 5, 2011 | 09:08 AM
Bushy's Avatar
Bushy
Question Accessory jack cable from Tourpak
Does anyone have a suggestion as to run cord from Tour Pack to radio from without going under tank.. is there a alternative,, 2012 Limited,, really don;t want to pick up tank unless last resort
_____
Posted this in Audio but no one was home_____________
Old Dec 5, 2011 | 10:00 AM
hopperop's Avatar
hopperop
Your tank is easy to take off. You should do it just so you know how. It is far from one of those last resort things.
Old Dec 5, 2011 | 10:32 AM
mkguitar's Avatar
mkguitar
what are you trying to do?
If it is get audio from a device in the tourpak to the radio, how about an FM modulator?
Mike
Old Dec 5, 2011 | 10:59 AM
Bushy's Avatar
Bushy
running a I-pod from Tourpak to radio...
Old Dec 5, 2011 | 11:11 AM
ssmith579's Avatar
ssmith579
Tank is simple to remove. Undo 4 bolts, pop off quick disconnect fuel line, unplug couple connectors and lift right off. Do it when almost empty and it doesn't weigh much.
Old Dec 5, 2011 | 11:16 AM
peddler's Avatar
peddler
I like the idea. Definitely interested. The 2012 Ultra Limited has the necessary 12 volt source in the tour pak. Is there also an (relatively) easy way to add the 12 volt source to older (2007) tour paks?
Old Dec 5, 2011 | 12:16 PM
62hdbiker's Avatar
62hdbiker
Tap into running lights in tour pac
Old Dec 5, 2011 | 01:52 PM
jberg's Avatar
jberg
Just remove the console along the top of the tank.
There's enough room to run several additional wires there.
Just follow the wires that are in there now and tie wrap them together.
I've run several wires through there already.
Aux, GPS audio connector, satellite antenna,etc.
All done to connect via a Mix-It sound board which enables me to connect and boost multiple devices through the aux port.
Old Dec 5, 2011 | 02:54 PM
MareRider's Avatar
MareRider
http://www.walmart.com/ip/iPod-wirel...itter/12961515
IPod wireless FM transmitter. Then listen on a FM setting over the radio.
HDTimFLHX
Jul 25, 2012 06:37 PM
EVOrider
EVO
Dec 22, 2011 03:29 PM
SharkBite
Apr 11, 2010 08:31 PM
shmedly
Oct 1, 2007 08:16 PM
brokenfingers
Mar 14, 2007 02:47 AM
