break in
Old Dec 1, 2011 | 07:24 PM
  #41
onaride63's Avatar
onaride63
Originally Posted by 07RoadHawg
I'm pretty sure I've never seen a race driver check their headlights, tail lights, and turn signals either. Apples do not equal oranges, but do it however you like.
LOL.thats because they don't have any.
Old Dec 1, 2011 | 07:37 PM
  #42
skratch's Avatar
skratch
Originally Posted by beary
basic reason came down to is if there is a manufacturing defect, the rider or driver could get hurt while being agressive. I understand that because that is why Harley suggest not riding over 50 mph the first 50 miles.
have you read an owners manual lately? harley does not recommend not riding over 50mph during the first 50 miles. at least not since 07.
from the 2012 owner's manual (which correlates with my 07 manual as well):
1. during the first 50 miles of riding, keep the engine speed below 300 rpm in any gear. do not lug the engine by running or accelerating at very low rpm, or by running at high rpm longer than needed for shifting or passing.
2. up to 500 miles, vary the engine speed and avoid operating at any steady engine speed for long periods. engine speed up to 3500 rpm in any gear is permissable.
3. drive slowly and avoid fast starts at wide open throttle until the engine has warmed up.
4. avoid lugging the engine by not running the engine at ver low speeds in higher gears.
5. avoid hard braking. break in new brakes with moderate use for the first 200 miles.
3000 rpm in 6th gear is somewhere around 70 mph, according to my tach. i've always just used the above as general guidelines when breaking in my bikes. never had an engine problem, nor an oil burning problem, and all my bikes have run strong.
Old Dec 1, 2011 | 08:05 PM
  #43
BuzzHD's Avatar
BuzzHD
Check this web page out.
http://www.ktm950.info/how/Orange%20...e_breakin.html
Old Dec 1, 2011 | 09:09 PM
  #44
2black1s's Avatar
2black1s
Originally Posted by BuzzHD
Good article! While break-in is a controversial subject, I'd tend to subscribe to the philosophy described here moreso than some others.
If you look at what I wrote earlier (post 10) about the way I did the break-in on my bike, it's similar. Not exactly the same but very similar.
Something else I thought about when reading this article that's a little bit of a tangent as far as this thread is concerned, yet it might be related to proper break-in, is all the complaints of oil dripping from the air cleaner. Maybe an improper break-in is the reason some bikes do it and others don't. If the rings never seated and sealed to there optimum level, could that be the reason for the excessive blow-by that results in excessive oil mist through the breathers and ultimately causing the drips from the air cleaner of some bikes? Interesting to think about, heh?
By the way, my bike has never dripped a drop from the air cleaner and I run the oil level at the full mark religously.
What do you guys think?
Old Dec 1, 2011 | 09:14 PM
  #45
Iceman24's Avatar
Iceman24
New engine break-in...30-60-30 in 3rd X10. Change oil & ride - gotta seat those rings!
Old Dec 1, 2011 | 10:28 PM
  #46
coolerman69's Avatar
coolerman69
I did a rolling burnout in the dealers parking lot the day i bought it. 60000 miles later no major problems.
Old Dec 1, 2011 | 11:35 PM
  #47
JetD's Avatar
JetD
Now that's funny right there.......
Old Dec 2, 2011 | 07:45 AM
  #48
coolerman69
And thats the truth! I'm a believer in breakin it in like your gonna ride it. Next time I was in the dealership they scolded me! LOL!
Old Jan 8, 2012 | 12:22 AM
  #49
rjhill's Avatar
rjhill
Originally Posted by 2black1s
What is break-in oil? I've heard this descriptor throughout my life but have yet to ever see an oil container that says "break-in" oil. I'm gonna call this an urban myth unless an expert can explain otherwise.
Along the same lines, there's the claims that you shouldn't use sythetics right off the bat. If those claims were valid why do several high-end high performance cars come with Mobil 1 from the factory?
I don't have the scientific answer for these questions, but I do have my opinion. And that opinion is these claims are simply heresay.
I've bought 3 new Vette's and they always have Mobil 1 from the factory.
Put a set of CNC heads and a cam on my last Vette at 30K and it looked new inside.
I change the oil every 4K since new. I really trust Mobil 1 infact I was thinking about using it in my SG.
Old Jan 8, 2012 | 08:41 AM
  #50
djkolp's Avatar
djkolp
Originally Posted by iclick
The break-in procedures I've seen over the past 50 years specified by manufacturers for any car or MC, even exoticars like Ferrari and Porsche, is for a progressive process. The specific wording varies but the general idea is always the same. I've never seen even one that recommends to "ride it like you would later-on" or "ride it like you stole it."
The important thing is to avoid sustained speeds, and don't use the cruise control (except to test it briefly, if you must). I mostly follow the book and use a progressive procedure all the way up to about 2k miles when I do my first synthetic oil change. That includes some mild acceleration followed by deceleration, which helps seat the rings, and that should be accomplished in the first 50 miles.
Thank you. I have used the procedures you describe above on countless bikes and cars over 35 years, and never had a single oil burner in the bunch. The 'Ride it like you stole it" statement made here by some is poor advice at best.
