Heated jacket liner
Old Dec 5, 2011 | 09:00 PM
jahays32's Avatar
jahays32
Default Heated jacket liner
For those that have the heated jacket liner, where did you bring your power wire out?
I was thinking at the front of the seat, any better ideas?
Old Dec 5, 2011 | 09:05 PM
soft 02's Avatar
soft 02
Thats where i put it. When i had it coming out the side it would come un plugged and scratch the fender. When i get my dual controller i am going to make a stainless mount at the base of the tank so it can be easily adjusted.
Old Dec 5, 2011 | 09:07 PM
speedwaysteve's Avatar
speedwaysteve
I have heat sheilds on my sg i have mine coming out from the top of the sheild where it meets the front of the seat
Old Dec 5, 2011 | 09:10 PM
MarineBagger's Avatar
MarineBagger
Mine comes out under the seat near the ignition wires. I tuck it away during the summer, and pull it out for winter.
Old Dec 5, 2011 | 09:12 PM
heavymetalthunder's Avatar
heavymetalthunder
I have it coming out the left side just below the seat. I zip tie it to the rear crash bar. I tried it in front of the seat and coming out of the center of the seat. This seems to work best for me.
Old Dec 5, 2011 | 09:27 PM
gtrb's Avatar
gtrb
Active Streak: 120 Days
I bought the Power Demon. It's mounted by the horn. It has two outlets for another accessory.
http://www.heatdemons.com/Dual-Port-...ey-1_p_14.html
Old Dec 5, 2011 | 09:53 PM
D2R's Avatar
D2R
I like the Powerlet connector, also plug a batt. tender in here.There are several different plugs you can use.One's mounted on my old Limited,the other on my Vic. Vision.
Attached Thumbnails Heated jacket liner-powerletplug-1-.jpg   Heated jacket liner-powerletplug006-1-.jpg   Heated jacket liner-new-20vision-20003.jpg   Heated jacket liner-new-20vision-20004.jpg   Heated jacket liner-powerletplug001-2-.jpg
Old Dec 5, 2011 | 11:49 PM
Dr. Tiki's Avatar
Dr. Tiki
I have my pigtail zip tied to the left side of the frame that goes down just behind the rear cylinder and under the seat. Tucked away nice and neat for the summer and accessible for the winter.
Old Dec 6, 2011 | 08:02 AM
blkfalc4's Avatar
blkfalc4
I use the Gerbings panel mount plug mounted to the left side heat shield on my bike.
Old Dec 6, 2011 | 08:07 AM
dyna-rider's Avatar
dyna-rider
I have mine coming out at the front of the seat & wired tied so it doesn't move.
