Cam install links?
Old Dec 24, 2011 | 08:38 AM
MichiganRider's Avatar
MichiganRider
Originally Posted by Teardrop
What size is a #43 drill bit?
.089 (2 sizes smaller then a 3/32) I'm glad we have these at work!
Wonder what size the hole is to begin with?
Old Dec 24, 2011 | 09:15 AM
atrain68's Avatar
atrain68
The bit size is .089". You can order one online or head down to Lowes and check the section that has tap and die sets. Look for the 4-40 NC tap. That should come with a #43 bit.
Old Dec 24, 2011 | 09:36 AM
Teardrop's Avatar
Teardrop
Thanks. I should be able to borrow one from work.
Old Dec 24, 2011 | 11:49 AM
stupid_rope's Avatar
stupid_rope
Originally Posted by clarkchriston
So other than the time to remove the tank and rocker box covers is there any advantage to using adjustable pushrods. Thinking about doing this myself and saving the $150 and re-using the stock pushrods unless there is some mechanical gain in using adjustable ones.
One last thing, I am assuming that the stock pushrods are not adjustable. If that is correct is it as simple as pulling them, installing the cams and inner beaings then putting the pushrods back in the correct slot. It just sound way easier than the whole adjustment thing.
Gaskets for the rocker box covers are an additional cost. Adjustables allow you to run a broader selection of cams.
Dont let the adjustment thing scare you, its much easier to do than it is to explain
iclick
Jun 4, 2024 08:07 PM
glasspilot
Engine Mechanical Topics
44
Jan 9, 2021 10:46 AM
Bryan3091
20
Apr 12, 2019 06:49 AM
Flhrhog
Dec 9, 2014 08:15 PM
Scramboogie
Exhaust System Topics
Dec 4, 2008 10:54 AM
