Nope, I had/have the same issue with my AN BS. You can see the oil trail from the so called raised ridges that are supposed to direct the blow-by oil into the mouth of the throttle body. The trail ended at the bottom of the backing plate, ready to drip into the filter. I'm running about 3 1/2 qts of oil, so I don't think it's overfilled. I guess it doesn't matter what make filter you run, if it's going to drip, it's going to drip.....
You are describing the issues correctly...the oil is dripping out of the breather ports, across the ridges, and down the back plate.
FWIW, I noticed the holes in the AN breather bolts seem somewhat smaller then the stock bolts (the ones that the rubber tubes attach).
Maybe the smaller AN bolts create a bit of a vacuum and actually suck some of the oil into the air intake instead of acting as an air pressure release???
This is what I did to my SE back plate to solve the oil drip problem...
I did the same thing with my old TC96. While that will effectively stop the oil from collecting at the bottom of the a/c, it will begin to build up in the throttle body.
With the motor shut down, remove the air cleaner and then gently open the throttle place itself...you may notice the throats of the throttle body coated with oil...maybe even a small pool of oil.
I just as soon not be dumping the oil into the intake if I don't have to...but that's just me.
here's what cured my buddies and mine, beings this is a closed loop system and the only thing that we figured would leak air was either the intake gasket or the 4 o-rings, so we did the o-rings, replace them with some from the hardware store, which were more beefier then the ones that came in the kit, put a little grease on the new o-rings and around the intake gasket just to be sure, buttoned it back up and took it for a ride and no more leak!! might want to give it a try.
