Stretched hard bags
Old Dec 24, 2011 | 03:57 PM
redglide75's Avatar
redglide75
Stage II
Default Stretched hard bags
Hello, I'm a new forum member and I ride a 2010 FLHX. I am looking to replace my bags and rear fender with stretched ones. What's the best brand and type out there? I have heard some say ABS and some say fiberglass. Any advise would be appreciated.
Thanks
Old Dec 24, 2011 | 04:26 PM
donf610's Avatar
donf610
through all my researching I went with Milwaukee bags and Bad Dad fender. Milwaukee bags are fiberglass and have a great interior finish. Fiberglass fender was nice to work with for frenched in led's
Old Dec 24, 2011 | 06:18 PM
ericl's Avatar
ericl
Just finished my mockup with sinister fender and bags, the bags are ABS, slightly thicker than the Harley Bags. The fender is a replacement not overlay. Quality is very high on both pieces, I have a small amount of trimming on the right exhaust cut out on the fender, the radius is slightly smaller than the left side. Here is my set up. I also installed cycle sound lids. The finished bike below is the same set up other than the lids. I went with cycle sound as I was concerned with the clearance with the detachable tour pak I use for when the
wife rides or for overnight trips. If you stay with Milwaukee, Top Shop, Sinister, yaffe, etc. you will do fine. Based on the research I did prior to my build, the consensus is the cheaper bags require additional prep work so the cost is basically a wash. Good luck and have fun on the project. Nothing like cutting on a$500.00 fender with a Dremil Tool. Regardless of your selection your going to have to tweak here and there to get a clean fit.
Old Dec 24, 2011 | 07:04 PM
piesik650's Avatar
piesik650
Here is a Baggernation Paul Yaffe Fender, and Ness saddlebags. Both are Fiberglas and were easy to mock up.
Old Dec 24, 2011 | 08:48 PM
BQsHX's Avatar
BQsHX
Sick Lids! I'm going with the Cycle Sounds lids, but I'm having a hard time find a reputable painter to get them sprayed....
Nice paint job, too!!! Def one of a kind!!!
Old Dec 24, 2011 | 08:53 PM
piesik650's Avatar
piesik650
cycle sound lids are pretty nice, I like mine
Old Dec 24, 2011 | 09:04 PM
roadgliderick's Avatar
roadgliderick
this is mine i just finished arlen ness big bags and bad dad rear fender which is a replacement not a overlay this fender is called the summit fender i also repainted the whole bike it was sedona orange now its firemist orange. love this color pics do it no justice.
Attached Thumbnails Stretched hard bags-1123111115.jpg   Stretched hard bags-1123111127.jpg
Old Dec 25, 2011 | 10:56 AM
yoyoman05's Avatar
yoyoman05
wife rides or for overnight trips. If you stay with Milwaukee, Top Shop, Sinister, yaffe, etc. you will do fine. Based on the research I did prior to my build, the consensus is the cheaper bags require additional prep work so the cost is basically a wash. Good luck and have fun on the project. Nothing like cutting on a$500.00 fender with a Dremil Tool. Regardless of your selection your going to have to tweak here and there to get a clean fit.n
[IMG]http://i1109.photobucket.com/albums/h434/ericl1/
c6905dfc.jpg[/IMG]
I have the same exact rear sinster fender and had to do the samething with dremeling it out..must be the mold..very very high quality tho
Old Dec 26, 2011 | 11:30 AM
09BlueRoadKing's Avatar
09BlueRoadKing
You would think that when you buy a fender replacement you wouldnt have to do any cutting on it to make it fit, definatley doing my homework before I shell out big bucks for mine.
Old Dec 26, 2011 | 03:59 PM
piesik650's Avatar
piesik650
I paid over $2000 for mine and thought the same thing. But I still had to shim and modify
