Checking Tire Pressure
Old Dec 31, 2011 | 12:04 PM
mkguitar's Avatar
mkguitar
the H-D gauge gouge is probably the better solution, as mentioned above.
90ş is less often used due to the danger should a rock hit it- sudden decompression on the freeway is no fun ( 3 X for me, various causes, one of which was valve stem failure)
the electronic TP units are cool, but get the one that installs inside the wheel- and have the wheel balanced for the extra weight.
the H-D gauge while expensive may be the value leader.
mike
Old Dec 31, 2011 | 01:34 PM
Krow's Avatar
Krow
Originally Posted by rooti
Thought this was pretty trick for the money...
http://www.bikebandit.com/bikemaster....mc_id=2783076
I think you'd have to be a contortionist to read the end of those on any tourer with saddle bags. I use an Accutire gauge: http://www.accutiregauge.com/motorcy...ressure-gauge/
It's easy to get on the stock stem and holds its reading.
Old Dec 31, 2011 | 02:17 PM
drukanfu's Avatar
drukanfu
Originally Posted by frenchbiker
Only thing working perfectly, FOR ME, is this. All the hose extensions and gauges that I bought before didn't really help. Replace your valve when you put a new tire on and you'll be glad you did.
http://www.motorcycleanchor.com/tire_valves/index.htm
Thanks for the link ! Looks like the sure ticket to me !!
When on the road it's bad enough to have to lay on the ground or to take a bag off ...... but when you burn your hand good on the hot disk once, well that's reason enough for me to get these.
Old Dec 31, 2011 | 03:10 PM
Chasenfish's Avatar
Chasenfish
Default digital guage from Home Depot
I picked up one of these. Works well, stores easily.
http://www.homedepot.com/Campbell-Ha...atalogId=10053
Old Dec 31, 2011 | 03:30 PM
2004Sierra's Avatar
2004Sierra
Here is the link to the gauge I use, it works great even without taking the bag off.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
The digital version:
Old Dec 31, 2011 | 04:10 PM
Terrabella's Avatar
Terrabella
I read somewhere that these things can fail while driving! Maybe someone else has heard this as well. Not to crazy about having the cap pressing down on the whatchamacallit all the time. Maybe ok for cars but....two wheels, scares me.
Old Dec 31, 2011 | 04:16 PM
TaterSaladonaRoadking's Avatar
It sucks, I just bend the rubber stem slightly and check it often, don't want to switch to a 90 for the sudden failure issue. I guess HD is hoping we will upgrade the rims
Old Dec 31, 2011 | 04:27 PM
Palau's Avatar
Palau
The following trick worked for me:
- buy a cheap bicycle pump
- cut the hose (at the pump side), discard the actual pump
- install a tire valve stem at the open end of the hose using a hose clamp
You now have an inflator hose that you can "easily" install on the bike tire valve stem. Using the other end of the hose, you can measure / inflate as needed using standard tools.
I obtained a used valve stem at a tire store, the net cost of this inflator hose was the cost of the bicycle pump and a hose clamp. I got this suggestion a long time ago from another member on this form.
Good luck.
Old Dec 31, 2011 | 05:22 PM
alphadog001's Avatar
alphadog001
This works the best out of all the stuff I have tried:
http://www.amazon.com/Campbell-Hausf.../dp/B0007ZJ1IK
Old Dec 31, 2011 | 07:00 PM
JJHOG's Avatar
JJHOG
Bottom line is HD has begun doing alot of short cuts in order to reduce production costs. Putting no forthought behind designing the location and positioning of the rear tire valve is really an insult to its customers. Especially when you consider we're paying well into the 20K's for a product that should be engineered better. All the way down to the tire valves.
