Rear Fender Tip Light
Old Jan 2, 2012 | 09:22 PM
Nute's Avatar
Nute
Default Rear Fender Tip Light
I've been changing out all my Lights to LED's on my '09 UC and come up against a snag. From all the drawings etc. I 've looked at the rear fender tip light should have two screws you remove from the wheel side of the fender. I found what I thought was the two screws but when I removed them all that happened was the whole light assembly came off the fender giving me no access to change out the bulb. I can't for the life of me figure out how one would change out the bulb. I can't seem to be able to get behind the red lens. Any ideas?
Old Jan 2, 2012 | 09:52 PM
mkguitar's Avatar
mkguitar
it already is LED.
you can take it apart if you want to, bend the plastic tangs so they'll slide through and pull, there is a soft glue/sealant that'll resist you.
I added red and blue leds to mine to add brake light function ( yes, I know they make them, but I had the parts and with the blue I have the old magenta blue dot look, red on the outside, blue in the center
Mike
Old Jan 3, 2012 | 06:29 AM
billnourse's Avatar
billnourse
I put a smoked one from Santa on mine. The instructions say that there are no servicable parts inside and not to take it apart. I just took the red one off and put the smoked one on.
Bill
Old Jan 3, 2012 | 08:09 AM
jberg's Avatar
jberg
Already LED. I replaced mine with the brake light version. Looks the same, plugs in the same way, functions as run and stop light.
bigrobtemp
2014-2024 Touring Models
Dec 14, 2015 12:29 PM
All Aces
Oct 4, 2014 08:29 PM
Airborne Limited
Apr 7, 2012 04:41 PM
hardwork2
Apr 8, 2011 07:02 PM
mca1989
General Topics/Tech Tips
May 3, 2009 08:11 PM
