changing shock oil
Old Jan 3, 2012 | 10:37 AM
HDJOE60's Avatar
HDJOE60
Default changing shock oil
Decided to change out the shock oil on my 06 street glide.Follwed what others have said. Took shocks off and using a pumping motion got all the oil out.13 ozs. in one side and 12 ozs. in the other side
Replaced with 10 ozs. of 10 wt. amsoil shock therapy.Used a funnel ,hose and connector to gravity feed in the oil.Put the shocks back on and went for a 70 mile ride with the wife. Bike rode good. very firm over bumps. No up and down several times like before but just up and down once.Had 15 lbs. of air in them.I will leave it like this for a while and see how they do.I think that 7-1/2 wt oil would be perfect also.
Old Jan 3, 2012 | 10:48 AM
Ronp42's Avatar
Ronp42
Account Retired
I did the shocks on my 2010 RK over a year ago using the Amsoil shock therapy 10 wt. I use about 5 lbs of air riding solo. Ride is firm, but I like it! My only other vehicle is a F250 Super Duty so I'm used to a firm ride.
Old Jan 3, 2012 | 11:01 AM
JJHOG's Avatar
JJHOG
Are you guys sure your "firm" ride isn't because you're running such a low amount of air pressure in your shocks. The Air Pressure represents your pre-load and typically you should be running around 40lbs solo and 50lbs 2up. With such a low amount of air you could actually be bottoming your shocks and that's whats feeling "firm" to you.
Old Jan 3, 2012 | 11:10 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
I run 15 pounds in mine..... I weight 190 pounds
Maybe you need a little modification
http://www.howtoloseweightfastb.com/
Old Jan 3, 2012 | 11:21 AM
Ronp42's Avatar
Ronp42
Account Retired
I'm not an expert, but I know I'm not bottoming out. I like the firmness! it's not too firm for me. I was bottoming out before I changed the oil and I was using as much as 40 PSI trying to stop the bottoming. I weigh 215.
Old Jan 3, 2012 | 11:43 AM
fabrik8r's Avatar
fabrik8r
First, the '06 SG 12" shock max pressure is 40, not like your '11 Ultra. different valving between those model years also. Second, they aren't running the original 5wt, they are running 10wt, which slows damping and allows you to run less air pressure.
XPress
2014-2024 Touring Models
19
Apr 25, 2024 06:49 AM
sigtau150
Sep 7, 2016 09:20 PM
Robtarra39
Jan 25, 2015 03:19 PM
capt_caveman
Apr 18, 2012 01:50 AM
beary
Aug 31, 2007 10:59 AM
