SE Compensator - Odd Noise
Old Jun 11, 2012 | 04:22 PM
  #41
stan60's Avatar
stan60
bump..
Old Jul 7, 2012 | 07:15 PM
  #42
SDVmnt's Avatar
SDVmnt
Installed the SE compensator on my 2010 SG early this spring. Have 4k miles on it and today I heard the knocking sound coming distinctly from the left side/Primary. Used the newer version and have had formula + in it. Interested to hear a resolution to this.. Hopefully it isn't going back to stock.
Starts 100% better now.
Old Jul 7, 2012 | 09:18 PM
  #43
Eric Moore's Avatar
Eric Moore
all this after I changed mine....hmmm..... wish the moco would get there parts worked out before sending them out to the public.. my bikes are not under warrenty... all out of my pocket.. hopefully thay hold up...I thought these were the answer
Old Jul 7, 2012 | 09:39 PM
  #44
jeeplite's Avatar
jeeplite
check my thread at SE junked......
Old Jul 7, 2012 | 11:03 PM
  #45
iclick's Avatar
iclick
Why would they do that when they can sell you the "new and improved" version and make more money?
Old Jul 8, 2012 | 10:48 PM
  #46
Mean Gene's Avatar
Mean Gene
I have a S.E. compensator installed in my 2008 Electra-Glide-Ultra-Classic, replaced , because of broken-tooth on original. Installed according to instructions. Cleaned threads, chased-threads with tap/die,cleaned with brake-cleaner, installed red-lock-tite, double-checked bolt torque, thought, I would never look-back, yet still more noise that I like. I have replaced inner-primary-bearing & race, checked automatic-tensioner, chain, alignment of chain, and am not sure what to do from here. Crusing say around 50-mph, there is this sort of chatter, changing speed, clutching seems to make it go away. Moving bike short distance and clutching, I hear something like the chain tensioner working. Running Vtwin Mobile-1, with Lukas, Motorcycle-oil-stabilizer presently, seeing if makes any difference.
Old Jul 9, 2012 | 09:49 PM
  #47
rare100thHD's Avatar
rare100thHD
I plan on removing my SE Comp soon, installed it less than 2 weeks ago.
Can't deal with the chatter after it warms up. Quite an perfect until you have
run 30-40 miles. Chatter Chatter Chatter on a 08 with IDS. This Chatter is why
I put the IDS on my 07 then later sold the bike. Now I have the Chatter problem
back, this time on my 08. WTF?? I would rather have the HOT Start issues than
clatter while cruising down the highway.
Old Jul 10, 2012 | 08:49 AM
  #48
archergodwin's Avatar
archergodwin
I've got about 10-15k on my SE comp. Generating a lot of noise now, and she jerks like crazy going through a parking lot. I changed to the SE comp, 'cause of hammer-like slap at startup. I had been planning to pull the primary again to see if anything amiss. Hell, then I catch up on the forum a little, and here's all these threads about the SE comp being a POS... frick. Guess my winter projects got a little deeper...
Old Jul 10, 2012 | 08:50 AM
  #49
soft 02's Avatar
soft 02
Remember you only here the bad. I got 49k on my SE comp and no issues.
Old Jul 10, 2012 | 09:02 AM
  #50
archergodwin
True enough.. I need to just get a new outer gasket and pull the cover to see what's up in there.
Deckman
Jan 30, 2022 09:24 PM
2008RKC08
Dec 7, 2015 08:48 AM
Reaper22
Aug 21, 2012 10:10 PM
inthechateau
Exhaust System Topics
Nov 15, 2011 10:23 AM
Pine Tree
Nov 14, 2010 11:09 PM
