Shift rod replacement.........good deal!
Old Jan 19, 2012 | 05:04 PM
  #131
KCFLHRC's Avatar
KCFLHRC
Originally Posted by Nirvana
I considered doing that, but I didn't think there was much thread left on the linkage rod.
That's true, there is not. Moving the shift levers is a better idea and gives you the full strength of the new rod.
Old Jan 19, 2012 | 05:15 PM
  #132
littlebear's Avatar
littlebear
As stated above mine was too long to. Had to take the lock nuts off each end and blue locktite it, will keep and eye on it.
Old Jan 19, 2012 | 05:27 PM
  #133
littlebear's Avatar
littlebear
After thinking about my post it occurs to me that the position of the forward lever (attached to the shift levers) will effect the lenght of the rod, shift levers will have to be repositoned, may redo mine,explains why some are too long and others to short.
Old Jan 19, 2012 | 05:58 PM
  #134
Clint55's Avatar
Clint55
There is plenty of room left on the linkage rod. The forces involved are linear, not shear. But..... if you really think you need more, then I guess you can buy 1/4 inch longer linkage rods at ACE while you are there getting the nuts. But not necessary IMHO. The result would be an increase of about 1/8th inch or about 3 more threads on each end of the linkage rods.
Just remember that its a 5 / 16th x 24 thread.
PS, if you do decide to adjust your shift levers..... I'd say to forget trying to adjust the rear. Major PITA to get to IMHO.
Old Jan 19, 2012 | 09:24 PM
  #135
TheGrandPoohBah's Avatar
TheGrandPoohBah
I'm in, I ordered the chrome shift rod this afternoon. Funny thing - the guy on the phone from Demon said "Let me check and make sure we have some left, for some reason we have sold a bunch of these this week". We all know why...
Also asked about fasteners, he said all included. I asked if the rods are "flat sided" like in their pics, he said yes, but had heard of some "rounds" like others mentioned on here. Said he would look into it, perhaps different suppliers. Should see it in 3 or 4 days, may come by USPS or FedEx, as others have mentioned.
Man, what have we started? It is a great value...
Old Jan 20, 2012 | 06:24 AM
  #136
FL-kruzen's Avatar
FL-kruzen
Wow! After installing my new shift rod I can find neutral really easily! What a difference this little upgrade makes! I think because you do away with the stock shift rod that has the movable joint on each end makes shifting much more positive. I love this new mod!
Old Jan 20, 2012 | 07:27 AM
  #137
nickel dime's Avatar
nickel dime
Mine came in just a hair shorter. Since both ends are right hand threads you don't have to worry about the rod changing length without the lock nuts on it. The worst that would happen is the center section would rotate forward or back but the ends would stay the same. The Locktite should hold it in place with no problem. Now if one end was R/H threads and the other end L/H threads (like a turn buckle) then you might have an issue.
Old Jan 20, 2012 | 09:27 AM
  #138
TUCCI's Avatar
TUCCI
Hummm I replaced my connections with Heim joints and was commenting to a friend the last time I was ridding that 4k must be the breaking point cuz I'm not having a tough a time popping it into neutral as much. It didn't occur to me the joints I replaced awhile back may be the reason?
Old Jan 20, 2012 | 10:06 AM
  #139
BCW567's Avatar
BCW567
Very nice and good review of the product
Old Jan 20, 2012 | 11:27 AM
  #140
PlotMH's Avatar
PlotMH
Mine's on order. Two comments:
1. Dawg, someone ought to approach these guys to sponsor the site if we are giving them this much business.
2. Keep this thread open to report reliability or any field issues with the linkage.
