2002 Wiring Harness on a 2000
Old Jan 8, 2012 | 04:45 PM
straightleg's Avatar
straightleg
Default 2002 Wiring Harness on a 2000
If I switch my MM EFI to a carb should I use the 2000 carb harness or the 2002
I read that 2002 you dont use a cam sensor? What do you use instead?
In the tank I understand the pingle conversion. Do I just leave the float in the tank and remove everything else?
All gas just goes down to the pet **** from each side??
Straightleg
Old Jan 9, 2012 | 02:34 AM
grbrown's Avatar
grbrown
Hopefully someone who has done it will call by soon. I would expect you can simply modify your current harness and remove parts of it you don't need. I have converted a later tank using a Pingel valve and yes, disconnect or remove what you don't need from inside the tank, so the float still works.
Old Jan 11, 2012 | 02:15 PM
straightleg
I think I better just go with the 2000 Carb Harness.
What would of came on it if it was built with a carb.I read plug and play
Straightleg
Old Jan 15, 2012 | 11:42 AM
straightleg
What ignition module part number comes stock on a 2000 carb / efi bike?
What coil part number comes stock on a 2000 carb/efi bike.....
I have the sevice manual, waiting on the part manual
Did not want to start another thread, just keep it part of this for future reference.
Thanks
Straightleg
BWann495909
Jul 12, 2022 03:32 PM
JakePie
May 15, 2019 09:01 PM
kicnit
Mar 16, 2014 07:39 PM
kicnit
Mar 25, 2013 06:58 PM
dakotalloyd
Jun 26, 2012 06:24 PM
