Gerbings Panel Mount Kit installed.
Old Jan 14, 2012 | 08:51 AM
Captain Itch's Avatar
Captain Itch
Sponsor
Originally Posted by Krow
It looks to me that with the Gerbings permanent mount dual controller you would have two plug-ins to connect each time you get on the bike. Is this correct?? You'd think Gerbing would include an adapter that would combine the two leads to give a single plug.
If I am following you correctly..2 different ***** for 2 different circuits. Mine is 1 for the gloves,and 1 for the liner..
__________________
www.Captain-Itch.com
Old Jan 14, 2012 | 09:50 AM
bdp's Avatar
bdp
permanent dual controller
Anyone doing this should know that if I had to do it again, the ***** would be inboard a little more. At hard over to the right, the ***** just touch the tank, but after a year I can't see a mark on the tank so must not be much.
Old Jan 14, 2012 | 11:01 AM
bagman1's Avatar
bagman1
I just got heated gear for Xmas and I went with Heatroller wireless controls, you only need to plug in the 1 main plug to the jacket and the control I velcroed to my center console for now until I figure another alternative. I like the idea of a weatherproof plug on the heatshield, that seems about the most logical place for it
Old Jan 14, 2012 | 11:28 AM
mike 1955's Avatar
mike 1955
Does the dual controller come with all you need? I like you set up.
Old Jan 14, 2012 | 12:06 PM
bdp's Avatar
bdp
The package has everything, but you will be plugging in to two loose connectors like this.... if you don'tbuy the panel connectors
Old Jan 14, 2012 | 12:09 PM
bdp's Avatar
bdp
I moved my loose connectors to the plastic piece shown here and use the coil 90* cord to plug in to my jacket. One plug in on each side of the seat. And if you're worried about drilling into this plastic, it only cost $4.00 if you screw up
PS plastic piece is on 09 and up models
Old Jan 14, 2012 | 12:19 PM
wheelman38's Avatar
wheelman38
Originally Posted by 3/4 life crisis
May I ask where do you get your right angle cord/adapter? Been looking for one. Thanks
Got mine on ebay. It was like 7 bux. Works great does not get in the way and unplugs easily if you forget to unplug when getting off. Bought 2 just in case.
Attached Thumbnails Gerbings Panel Mount Kit installed.-cnt-c4-plug2cable.jpg
Old Jan 15, 2012 | 03:17 PM
knewt5's Avatar
knewt5
What search term did you use to find that right angle plug?
Old Jan 15, 2012 | 04:23 PM
Twinrider's Avatar
Twinrider
Here's another option. Remote Heat-Troller from Warmnsafe. Remote sender unit tucks away in your heated jacket, controller unit velcro-mounts to your bike. One power wire from your jacket to the bike. That's it.
http://www.warmnsafe.com/index.php?m...roducts_id=257
Old Jan 15, 2012 | 06:38 PM
av ultra's Avatar
av ultra
i got the remote, works great.
