Yellow wire
Old Jan 15, 2012 | 03:36 PM
2007rkjb's Avatar
2007rkjb
Default Yellow wire
Hello.
Just took the seat off my 2007 RKC and I have a yellow wire with a dark stripe coming from under the gas tank and going to nowhere. The end seems to be broken off and just hanging by the battery. I suspect that it is my directionals and brake light. ( Sorry, my shop manual is at work ). Just trying to figure out where this wire belongs. Any ideas ?
Thanks in advance,
Jake
Old Jan 15, 2012 | 04:04 PM
krazy3's Avatar
krazy3
I believe there is a Yellow/Black that runs to the horn. It would help to know the second color.
Old Jan 15, 2012 | 05:20 PM
z71_fourwheelin's Avatar
z71_fourwheelin
There is only three "yellow w/ stripe wires" 1. horn 2. system relay 3. rear coil
Old Jan 15, 2012 | 06:42 PM
2007rkjb's Avatar
2007rkjb
Default Yellow wire
Hi again,
Wire is yellow with a blue stripe.
It must connect in the area under the seat somewhere.
( It's about 7 degrees in my garage in Boston.
I am so cold I can barely type ).
Thanks again for any help.
Jake
Old Jan 15, 2012 | 08:01 PM
krazy3's Avatar
krazy3
If I read the EDM right, Yellow/Blue (Y/BE?), goes to the rear coil. I don't know though, I'm no electronics guru.
Old Jan 16, 2012 | 01:49 AM
z71_fourwheelin
My bad yes there is a y/be it is rear coil and its pin 53 on your ecm or should be
13RoadKing
Electrical/Lighting/Alarm
Feb 28, 2017 07:17 PM
Bigwingboy
Dec 11, 2014 09:45 PM
Afishionado
Nov 21, 2012 09:00 PM
brandanfinn
May 12, 2009 08:43 AM
MontanaPanFan
Panhead
Sep 19, 2007 04:50 PM
