12v access point
Old Jan 20, 2012 | 01:47 PM
2of2's Avatar
2of2
Default 12v access point
I will be adding a 12v access point and tapping power from the fuse box to supply it. I don't remember from the last time I had the side cover off if there is an easy way to tap into the fuse box. Anyone with experience in this matter? I would like to have an idea before I get started tomorrow. 2008 FLHT. Thanks
Oh yeah... also installing the HD engine heat shields. Any tips on setting the well nuts? I heard it is a pain. Thanks
Old Jan 20, 2012 | 02:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
i would use the 12 volt aux port,easier than tapping fuses,and its switched.
Old Jan 20, 2012 | 03:31 PM
2of2's Avatar
2of2
Wasn't sure what that was. I got the part from the dealer. Looks like it is what I need
Old Jan 20, 2012 | 03:51 PM
Harleypingman's Avatar
Harleypingman
As for the heat shields, I installed them a year or so ago on my '04 EG--same frame, space, etc. as your '08. It was easily the biggest pita project of the many, many mods I've made to my bike because the space is so limited between the frame and rear cylinder valve cover. My only suggestion is to create as much space as you can under the seat for your hands. I don't recall the details--probably a desire to forget the frustration of installing the heat shields.
Good luck with your projects.
Carl
PS: It occasionally helps to say what it is you are trying to accomplish--others may have experience that will help you.
Old Jan 20, 2012 | 04:06 PM
kingkingking's Avatar
kingkingking
Switched or always on?
Old Jan 20, 2012 | 06:01 PM
bgdv1's Avatar
bgdv1
my 11 SG has a constant hot and a switched hot plugs onder my seat. they each use a different connector. ive hooked the switched out to power my ipod/iphone as to not over charge by being constantly hot.
Old Jan 20, 2012 | 06:12 PM
2of2's Avatar
2of2
That's the way to go. Thanks
Old Jan 20, 2012 | 06:38 PM
RandyS's Avatar
RandyS
I just tapped into the running lights in my tourpak
Old Jan 20, 2012 | 08:39 PM
bigdumbnoitall00
in the port there are 4 holes one is switched on tax,one on ignition,on hot,one ground,use a 12 volt test light to figure with one u want, use a crimp on duetch connecter(about 10 cents) and plug it into the hole ,no need for a 20$ harness.
Old Jan 20, 2012 | 09:03 PM
2of2's Avatar
2of2
Thanks for the information. I already bought the harness so I will use it. This is a lot better than what I had in mind.
Mr Dirt
Nov 24, 2013 02:38 PM
tslonige
Sep 4, 2009 09:46 AM
jpmflying
Jun 16, 2008 06:53 PM
sdroadglide
Apr 10, 2008 12:02 PM
russl179
Jul 20, 2007 09:18 AM
