cam bearing failure
Caged bearings are more expensive to produce than full complement bearings, and the INA bearings are German-made, high quality bearings. Caged bearings allow more lubrication of the cam journal, and are designed for higher rpm applications. Full complement bearings are designed for applications where higher torque loads are encountered.
For me, the jury's still out, but I'm skeptical by nature. I still have some difficulty believing the full complement Torringtons are necessarily an upgrade, even though I put them in my bike at the last cam change. I don't think changing to the full complement Torringtons is a mistake, but I still don't believe it's absolutely necessary.
One of these days, we'll probably get plain inner cam bearings.
Interesting points made between the two bearings, I completely agree with the rpm vs load references.
The Full Complement style offers greater surface contact area resulting in a load more evenly spread, it is naturally better suited to distribute high loads. But the drawback is, greater contact area will result in the undesirable increased friction with high speeds.
The Caged style has less surface contact area is better suited for higher speeds, and lighter loads. But higher loads will result in much more pressure on smaller areas and eventual failure.
So, the question is, where in the spectrum does a Harley motor fall? Higher loads or higher rpms?
Something to consider, 5000 - 6000 rpms is not considered high speed. At least not in the world of bearings, especially when only done in short bursts. But the amount of load being trust around in these motors is worthy of being considered high, especially when a cam upgrade and other performance modifications are done.
And what are your planning, or what have your done with this latest Cam change? Leave the old Torrington's, Mew Torrington's, or new INA?
