Battery Issue (voltage draw)
Old Jan 29, 2012 | 11:49 PM
BC45's Avatar
BC45
Originally Posted by CHILLLS
so wouldnt you take your multimeter switch it to amps put one end on the pos on the battery & the other on the pos cable to see what the amp draw is & then start looking for the culprit....no?
Yes but it is better to test off the neg side not the poss side,And it is better if amp meter can read milli amps because a 340ma draw can drain a auto battery down in around 10 days sitting and bike battery's would even be faster.
Old Jan 30, 2012 | 04:22 PM
workformetoo's Avatar
workformetoo
Thanks everyone for the info, will check it tomorrow when I get the bike back.
Old Jan 30, 2012 | 06:16 PM
Gitarded's Avatar
Gitarded
Its not the voltage its the amperage. The clock and ECM are drawing power even when the bike is off. This is minimal current. You should check with an amp meter inline between the positive battery cable and the positive post on the battery. The meter needs to be in series with the circuit. You should read probably less than an amp. If you are seeing a big draw, something is wrong and may be why your battery failed in addition to age.
Also, Advanced auto sells batterys for harleys that are from east penn for about $60. East penn makes the Harley OEM battery, its a different case with bars and shields. Not worth an extra $50. Same battery.
Batteries should be on tenders when the bike is not driven for a few days. The plates will sulfate with no charge and it will cause early life failure.
Jcwilliams307
Jun 22, 2017 09:52 AM
WOLFE1584
Mar 12, 2013 01:13 PM
slipvayne9278
Jul 22, 2011 12:39 PM
fuzzko
Nov 14, 2005 04:46 PM
HDF Tech
Electrical/Lighting/Alarm
Jun 25, 2005 01:26 AM
