View Poll Results: True Track, Glide Pro or OEM Stock
True Track
38.71%
Glide Pro
29.03%
OEM Stock 2009 up models, live with it
32.26%
Voters: 31. You may not vote on this poll
True Track Vs Glide Pro Bushings
Old Jan 31, 2012 | 10:00 AM
trackadaptor's Avatar
trackadaptor
Default True Track Vs Glide Pro Bushings
http://www.true-track.com/ http://www.true-track.com/
Winter Mod, going with one of these
Ok what you think - pics would be great
Old Jan 31, 2012 | 10:34 AM
qtrracer's Avatar
qtrracer
Do one, then the other, then both I would listen to someone like yourself after that kind of test. I expect fans of both claiming their product of choice is superior. I have only tried True Track. It did what it was designed to do. But after about 3 or 4,000 miles I have picked up a weird light knock(a sharp road jolt sometimes brings it about) that I can't find and I have a hard time reproducing. I think it's a motor mount but I just don't know.....yet.
Old Feb 1, 2012 | 01:36 PM
trackadaptor
So nobody is really using these by the head count....
Old Feb 1, 2012 | 01:56 PM
fabrik8r's Avatar
fabrik8r
Sta-Bo does the same thing for a lot less money
Old Feb 1, 2012 | 02:08 PM
ocezam's Avatar
ocezam
Edit: I don't think Sta-Bo's are made for '09 and up frames.
Old Feb 1, 2012 | 02:56 PM
05RKCRider's Avatar
05RKCRider
05 RK Classic with go/stop fast goodies. I had a shimmy at 80-85 mph when stock so I put on True Track, shimmy gone, smooth too 115+. Was even better after I went to Avon Venom X tires & ditched the stock Dudlops, although I been reading good things about Dunlop Elite 3. I may have to try some.
Old Feb 1, 2012 | 05:42 PM
fabrik8r's Avatar
fabrik8r
They work on 09s and up; Harley didn't change the rear isolator sytem, they just added another front motor mount.
Old Feb 1, 2012 | 07:11 PM
$tonecold's Avatar
$tonecold
I was curious about this some time back so I called StaBo and I was told that for the 09's and up they just recommended changing the swingarm bearings to their heavy duty bearings. According to the Kevin the stock isolators on the 09's and up work pretty well. Also KingKingKing just installed a True Track and he doesn't seem very impressed by it. I do believe that he rides beyond the limits of the average rider though.
Old Feb 1, 2012 | 07:51 PM
Primo's Avatar
Primo
True-Track in the back and Glide-Pro front motor mount= Nice combination.
Old Feb 2, 2012 | 05:33 PM
true-track's Avatar
true-track
quote: Also KingKingKing just installed a True Track and he doesn't seem very impressed by it. I do believe that he rides beyond the limits of the average rider though.
True-Track is designed for stock rubber mounted Harleys. To not be very impressed with a product when it isn't used for it's intended purpose - this shouldn't be surprising.
