Solo seat without driver backrest? No problem!
Old Feb 3, 2012 | 08:46 AM
2manytoys's Avatar
2manytoys
Default Solo seat without driver backrest? No problem!
For a few bucks and a trip to the hardware store you can convert your short passenger backrest to a drivers backrest in 10 minutes or less.
I loaned my C&C solo seat with backrest to a friend who wanted to try it out for awhile. The weather turned nice and I wanted to ride but needed a backrest. The 2012 CVO Street Glide seat has no provisions for a drivers backrest so I made my own. I reversed the pad on my short passenger backrest and mounted the upright backwards on the shock mount. Then removed the mounting bolt of the front saddle bag support and installed a stainless steel turn-buckle using a 1/4" by 1" bolt. Bolted detachable spools from a leftover detachable mount to the other end of the turn buckle and presto! It has a little forward movement on the shock mount but is solid as a rock when leaned against. Doesn't look too bad in a pinch.
Solo seat without driver backrest? No problem!-backrest-002.jpg Solo seat without driver backrest? No problem!-backrest-005.jpg
Solo seat without driver backrest? No problem!-backrest-001.jpg Solo seat without driver backrest? No problem!-backrest-007.jpg
Old Feb 3, 2012 | 08:59 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
That's freaking brilliant. You might want to replace the plastic latches with the chrome ones, for a little extra strength. http://www.harley-davidson.com/gma/g...bmLocale=en_US But brilliant none the less.
Old Feb 3, 2012 | 09:06 AM
Ronp42's Avatar
Ronp42
Account Retired
Great idea! You must have an Engineering background to come up with that. Looks great!
Old Feb 3, 2012 | 09:33 AM
TUCCI's Avatar
TUCCI
Or pretty good with McGyvering and re-fabrication.....good job.
Old Feb 3, 2012 | 09:46 AM
2manytoys's Avatar
2manytoys
Yes on the latter. I stood there with my backrest in one hand and a scotch in the other...pondered untill the scotch was gone then went to the hardware store.
Old Feb 3, 2012 | 10:32 AM
10 RED RK's Avatar
10 RED RK
Brilliant idea!! I've got a Mustang seat I'm gonna try that on!!!
Old Feb 3, 2012 | 11:53 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
WOW!
Great fine! Would you mine posting what you had to pick up at the local hardware store? I never use my short sissy bar and may convert it to your set up
Thanks,
YB
Old Feb 3, 2012 | 11:57 AM
Beav's Avatar
Beav
EXCELLECT IDEA!!!!
HD will make that a $200 option next year!
Old Feb 3, 2012 | 12:04 PM
knewt5's Avatar
knewt5
I love it. I'd been thinking about tinkering to figure out if it could be done. Nice job...way cleaner than I would've come up with!
Any idea where I could get the spools?
Old Feb 3, 2012 | 01:48 PM
ReidRik_Von's Avatar
ReidRik_Von
Often the best ideas are the simplest and this is brilliant. I am going to give this a try with my stock police seat and see how it works.
Edit...
So I got a chance to fit the backrest and it looks good:
Now I need to go to the Tacoma Screw for the parts or maybe one of the local marine stores for chrome pieces...
Awesome, another project.
