Help with exhaust
Old Feb 5, 2012 | 04:15 PM
Tek74's Avatar
Tek74
Check out the Klock Werks SS mufflers on this You Tube Link.
http://www.youtube.com/watch?v=ZmIMyWM0YxE
Old Feb 5, 2012 | 04:26 PM
Tom Hudson's Avatar
Tom Hudson
Originally Posted by 1931jamesw
This....
PM sent
Old Feb 5, 2012 | 04:31 PM
1931jamesw's Avatar
1931jamesw
PM returned, Tom.
Old Feb 5, 2012 | 11:45 PM
Joboo1966's Avatar
Joboo1966
Plenty of good answers but heres the down low on exhaust as you need to keep this in mind as it all ties in.
Your Harley exhaust system is an important part of the components that control airflow through your engine. Other important components include the induction system, cams, and heads. To get the best performance, these components must be tuned together, through a given rpm range. If one of these is changed or modified, the group of components must be retuned to get the maximum performance.
It's important to remember that a louder exhaust system does not always mean better performance. Dyno tests have proven that there is no direct, proportional relationship between sound levels and power. Some quieter aftermarket mufflers actually make more power than some louder ones.
An optimized exhaust is designed to achieve balanced pressure between the engine's intake and exhaust within a given rpm range. The range of 2,000 to 4,000 rpm is usually best for street use. The range of 4,500 to 5,000 rpm and higher is more important for racing applications. No Harley exhaust system performs efficiently through the full rpm range. Knowing this, priorities have to be determined and some compromises have to be made.
HERE'S HOW IT WORKS
The exhaust valve opens, gases go past the valve and create a positive pressure wave that travels out the header pipe. As this positive wave exits, it is converted into a negative wave which moves back up the pipe toward the valve. These positive and negative pressure waves pulsate between the open end of the pipe and the exhaust valve. With the right pipe length, the negative wave will arrive at the exhaust valve during the valve overlap. The negative wave reduces pressure at the valve and helps scavenge combustion gases from the chamber.
Pressure waves can only be timed over a narrow rpm range. The rpm range should be determined so pipe length can be matched to the rpm band. Shorter pipe length improves higher rpm performance. Longer pipe length improves lower rpm performance.
When considering a Harley exhaust, remember there are sometimes tradeoffs between looks and performance. Exhaust system design has a big impact on engine performance. Header pipe diameter, bend radius, pipe length, muffler volume and design of the baffle effect performance.
If the pipe is too long or too short or if the diameter is too big or too small, performance will suffer. Performance also suffers when airflow is restricted by the mufflers. Bigger engines generate more exhaust and need bigger higher-flowing mufflers, but looks can often suffer with increased muffler size.
Harley-Davidson engineers know which header pipes work best in terms of deminsions, so most of the time a set of slip-on mufflers will give you a good performance boost, without the added expense of changing the header pipes.
Here's a look at different types of Harley-Davidson exhaust.
TRUE DUALS
True dual exhaust systems use a separate pipe for each cylinder. This design provides a balanced flow for both cylinders.
TWO-INTO-ONE
The two-into-one design merges both header pipes into a tapered collector. Two-into-one exhaust systems tend to increase low and midrange power.
STRAIGHT PIPES
Two-into-two straight pipes can improve top-end performance but low and midrange power suffers. Throttle response below 3,800 rpm is usually poor. These pipes are also very loud for street use.
STEPPED HEADERS
Stepped headers are divided into two or more sections. Each section is a minimum of 1/8 inch larger in diameter than the previous section. Stepped headers perform better on large-displacement and or higher rpm engines.
SLIP-ON MUFFLERS
Slip-on mufflers are an excellent choice since your keep your stock Harley exhaust pipes while adding improved performance and better sound. Since the original pipes are kept, velocity and lower end torque is retained. Slip-on mufflers increase flow compared to factory mufflers which are restrictive because of EPA regulations. Screamin Eagle slip-ons are a popular choice for Harley riders, especially for touring models.
Regardless of which way you decide to go be certain to take your completed configuration to a trusted HD dealer and have the system tuned and dyno'd to optimize your investment. In my opinion you should choose something that provides at least some back pressure, going with a quiter exhaust is the only way you will get the "perfcect" combo.
Old Feb 6, 2012 | 05:23 PM
Tom Hudson's Avatar
Tom Hudson
HERE'S HOW IT WORKS
TRUE DUALS
TWO-INTO-ONE
STRAIGHT PIPES
STEPPED HEADERS
SLIP-ON MUFFLERS
IS THAT ALL YOU HAVE TO SAY ABOUT THAT! dem - I bought slip-on SE's & a big suck set-up - i'll get the bike tuned when I get the stuff installed - thanks guys big help! Tom
Old Feb 6, 2012 | 05:49 PM
1931jamesw's Avatar
1931jamesw
Enjoy your new exhaust, Tom!
Old Feb 7, 2012 | 09:32 PM
Tom Hudson's Avatar
Tom Hudson
never mind i found it
Old Feb 11, 2012 | 04:30 PM
Tom Hudson's Avatar
Tom Hudson
I have a set of Screamin Eagle slip-ons I'll sell you. PM me if you're interested. They are part number 80721-09.
James - check your e-mail - the tracking number you sent me say's my package was dropped off in Texas on the 9th?
rotherdrummer
Aug 29, 2014 11:43 AM
2011Iron883
Nov 9, 2012 03:36 PM
JR Samples
Jan 17, 2008 09:38 AM
1peter
20
Jul 19, 2007 07:29 AM
LowriderFXRS
Feb 22, 2007 01:54 PM
