Clean your IAC
Old Aug 3, 2015 | 01:13 PM
nvsteve's Avatar
nvsteve
The IAC orifice is in front of the butterfly in the 12 o'clock position.
Turn the ignition on. Turn the run/stop switch on and off while spraying cleaner into the IAC orifice.
Old Aug 5, 2015 | 09:09 PM
kerstingm's Avatar
kerstingm
I have read about the rear cylinder shutoff system, never did verify that my 07 has it or not? I have the air filter out now, I found the breather tubes dried out and one has a Crack in it, also found the gasket behind the filter broken in a couple of places. The sensor does look dirty, I took pictures before cleanimg, will take some after.
thanks for info
Old Aug 6, 2015 | 07:47 AM
nvsteve's Avatar
nvsteve
thanks for info
In 07 the dealer had to activate the rear cylinder shut off on request.
Old Aug 7, 2015 | 02:55 AM
kerstingm's Avatar
kerstingm
[QUOTE=nvsteve;14275709]In 07 the dealer had to activate the rear cylinder shut off on request
How can I find out if it was activated? I will check my owner's manual again.
I did notice after cleaning the sensor when I started the engine it did run smoother, and around 1,100 rpms. I have my new breather tubes and air cleaner filter gasket, will replace today to see if it changes anything.
thanks again the info
Old Aug 7, 2015 | 10:36 PM
bundy43's Avatar
bundy43
How doe's cleaning the IAC help fuel millage.
sbeast
Jun 24, 2017 09:57 AM
SWThomas
Jan 11, 2015 11:48 AM
jpbo
Jan 9, 2011 10:05 PM
JefFLH
Apr 27, 2009 12:34 PM
JefFLH
Apr 27, 2009 12:11 PM
