Changing Brake Line... ABS ?
Old Feb 8, 2012 | 10:36 PM
murph's Avatar
murph
Default Changing Brake Line... ABS ?
I'm getting ready to install apes on my 12 Street Glide. I will also be changing the upper and lower brake lines.... I'm worried about getting air in the ABS unit. I need a little help here. Does anyone know how to change upper and lower lines. I have searched, but everything is about upper only. If I was to accidentally get air in the line, could I still ride the bike to the dealer and have them put it on the DT system to bleed it?
I think I could change the upper lines first... Reverse bleed the lines until the reservoir is full...flicking the upper lines as I do this. Then change the lower line and vacuum the lower lines until fluid comes out without bubbles.... Let me know what you think.
thanks in advance.
Old Feb 9, 2012 | 06:13 AM
tj316's Avatar
tj316
I did uppers and lowers basically that way , rode to the dealer and had them digi tech it to be safe , I just rode it in early on a Sat with light traffic to be safe
Old Feb 10, 2012 | 10:32 AM
murph's Avatar
murph
Thanks for the input. I hope it works... If not, I will be riding a bike with no ABS to the dealer....lol
Old Feb 10, 2012 | 10:35 AM
sgdiesel's Avatar
sgdiesel
No ABS would be far less of a concern than very mushy brakes, but that said I would do exactly as you plan
Old Feb 10, 2012 | 10:52 AM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
Ya know I keep reading all this about having to bleed with the DT at the dealer. and I know car abs is slightly different, and while the manufacturer says to bleed system with scanner attached, we all have learned that it bleeds perfectly without using scanner and mercedes says you dont even have to use one just bleed as normal. we use a brake bleeder which puts pressure on the reservoir but we just bleed it even when replacing the hydro unit. ( abs pump/module) in fact just did another one yesterday. I wonder if the harley one will work the same way. In my mind it should. if anybody wants to try to bleed it the normal way, even after getting some air in, the worst that can happen is it goes to dealer anyway. but as long as you get a good pedal/lever pressure and no light (abs light), it should be just fine. I'm getting ready to put chrome calipers on in a month or so, I'll try it myself them, but if anybody else wants to find out, try it, you can't ruin anything and just don't ride it if brakes are soft
Old Feb 10, 2012 | 01:14 PM
Eric in chicago's Avatar
Eric in chicago
I am going to try the above as harleycharley1992 describes. I have a motive bleeder that I used on my race cars with ABS. Can imagine pushing fluid thru the system will not do the trick. got to look at the ABS module to see if I need to crack the lines to let the air out.
On the Porsche racers, I just bled the systems of air and it was good to go. Will be doing the bleed next weekend and will report back.
Old Feb 10, 2012 | 01:59 PM
rg_dave's Avatar
rg_dave
Your plan should be fine. One line at a time and don't get air into the ABS module and you should be golden. Worst case take it in and let dealer hook it up to the Digital tech.
Old Feb 10, 2012 | 04:05 PM
harleycharlie1992
on benz you just push the fluid thru. it will fill the chambers inside the hydro unit. I sure don't know if the harley one will or not but abs is abs, as far as the hydro unit works. I think you should be able to push it all the way to caliper give it a try
Old Feb 11, 2012 | 10:59 PM
Potato_Potato's Avatar
Potato_Potato
If you get air in the system get the air out with a bleeder just as you would with non-ABS. Your brakes will work safely. The only thing that might not work in the ABS function. They will still stop you as well as the millions of bikes on the road without ABS.
You can ride your bike to the dealer to check the functioning of the ABS via the DT.
This is from the service manual:
If motorcycle is ABS equipped, and either the ABS module or more than one brake line was removed, confirm that brake system is properly connected. To accomplish this, connect motorcycle to DIGITAL TECHNICIAN II (Part No. HD-48650) and perform "ABS Service" procedure in the "Toolbox" menu.
Old Feb 12, 2012 | 11:02 AM
murph's Avatar
murph
Thanks for the info. Sounds like I can't go wrong. Anyone know where I can get a large syringe.??
