True dual question
Old Feb 12, 2012 | 11:28 AM
dgdamore's Avatar
dgdamore
I always thought this was an area of unnecessary compromise for HD. The '08 and earlier suffered from extreme heat for the passenger and less then optimal flow due to the hard left turn the exhaust gasses make immediately when leaving the combustion chamber. On '09 and newer, the linguini shaped section of pipe under the trans also leaves much to be desired flow wise. Always thought they could've cast a rear cylinder head that had the exhaust port on the left side of the bike or even straight out the back of the head. Then the header could be routed directly over the transmission and (well heat shrouded), and out the left side of the bike behind the passenger foot rest.
Old Feb 12, 2012 | 11:37 AM
mgmmgm's Avatar
mgmmgm
Default Hmmm
Originally Posted by Grillfish
Dang- i might have gone with those Rinehart TD's..... oh well.
Old Feb 12, 2012 | 11:56 AM
LKHA's Avatar
LKHA
Originally Posted by NDBadlands4-2
I put Vance and Hines true duals on my 2012 Ultra this winter. The pipes follow the same path as the stock pipes, except that they do not merge where the catalytic converter used to be. I liked it because it really did not change the look of the bike. Only the performance and sound.
can you clarify for me do they decrease in size like the stock pipe where it crosses under bike thanks
Old Feb 12, 2012 | 12:31 PM
dgdamore's Avatar
dgdamore
I have the same set up and yes, they do appear to decrease in size, however it doesn't appear to be as much as the stockers. The pipe flattens out under the trans, but it looks like the overall diameter is close to the same. More like fettucini then linguini if that helps at all. lol
Old Feb 14, 2012 | 12:10 AM
MGS Performance's Avatar
MGS Performance
Former Sponsor
MGS True Duals don't route under the bike. Stepped headers, customized tips, and great power increase. Nice deep throaty sound too.
Old Feb 14, 2012 | 07:27 AM
HighLiner's Avatar
HighLiner
That dyno chart can't be right everybody says true duals kills your bottom end!
Old Feb 14, 2012 | 10:09 AM
MGS Performance
Former Sponsor
Dyno chart is right. The infamous everybody and they once said the world was flat too! We're here to tell you that the world is round and our true duals will out-perform any pipe out there. We just took off a 2-into-1 thunder header from a customer's bike and installed a set of our true duals. The dyno sheet was staggering! I'll post the video and print out this week.
Old Feb 14, 2012 | 01:27 PM
HighLiner's Avatar
HighLiner
It was a joke! LoL
Old Feb 14, 2012 | 02:11 PM
MGS Performance
Former Sponsor
It was a joke! LoL
Good one! Should've seen it, that one went over my head! You never know these days..... We thought that myth was debunked years ago, but still hear it all the time! Funny how things get around that aren't true.
Old Feb 14, 2012 | 02:41 PM
fabrik8r's Avatar
fabrik8r
Did you tune the bike after installing your pipe, or did you just bolt this on and do a dyno run?
