True dual question
Old Feb 12, 2012 | 12:15 AM
MegaFauna's Avatar
MegaFauna
Default True dual question
Noticed on the 09 and newer touring models most true dual headers aren't available in the "cross over" style, meaning the rear headpipe does not cross above the transmission on the left? Is there something different about these years that prevents this?
Old Feb 12, 2012 | 12:22 AM
mkguitar's Avatar
mkguitar
I'm guessing they are trying to keep heat away from the passenger.
Some of the old TD designs took hits as they might not allow checking the oil etc.
And routing to the right and back under will allow for more even length exhaust tracts ( front and rear) which is good.
Mike
Old Feb 12, 2012 | 06:00 AM
Grillfish's Avatar
Grillfish
Here you go.. "classic".
http://rinehartracing.com/exhausts/true-duals/100-0301
Old Feb 12, 2012 | 06:16 AM
hougz79's Avatar
hougz79
Personally I prefer the "newer" TD look. I like both, but I like that you get closer to equal length headers with the "tuck and wrap" style like the new Dresser Duals and such.
Old Feb 12, 2012 | 09:01 AM
RHillbilly's Avatar
RHillbilly
I didnt like how the rineharts crossed each other at the tranny cover so went with v&h duals like the way they look sound good to
Old Feb 12, 2012 | 09:05 AM
blusmbl's Avatar
blusmbl
Bub, Rineheart, Bassani and Samson all offer true duals with the rear cylinder's exhaust being routed over to the left side of the bike.
Old Feb 12, 2012 | 09:17 AM
Iceman24's Avatar
Iceman24
I preferred TD's that didn't route under bike to get to Left side...love my Bub-7 TD's!!!
Old Feb 12, 2012 | 09:30 AM
LKHA's Avatar
LKHA
the x on the right makes it closer to the dip stick and if like the stock pipe(I have not seen personal) the cross under pipe may have been reduced in diameter for ground clearance. I do like the equal length idea but not the look and possible draw backs so i went with the classic RHs and love them
Old Feb 12, 2012 | 10:38 AM
HighLiner's Avatar
HighLiner
I have the Rinehart classics and they are sweet.
Old Feb 12, 2012 | 11:15 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I put Vance and Hines true duals on my 2012 Ultra this winter. The pipes follow the same path as the stock pipes, except that they do not merge where the catalytic converter used to be. I liked it because it really did not change the look of the bike. Only the performance and sound.
