Headlight visor
Old Feb 12, 2012 | 01:38 PM
Milehighturbo's Avatar
Milehighturbo
Default Headlight visor
So i must be an idiot i can not get this headlight visor to close at the seam as i tighten it and there is a gap between the light and visor bezel
what im i doing wrong?? i followed the instructions and still fits like poop!!
Old Feb 12, 2012 | 02:10 PM
1st 96 ultra's Avatar
1st 96 ultra
not a idiot but just missing something , can not really understand what you are talking about with the gap the head light ring goes in a groove in the head light bucket or mount , we all call things different names , get your service book out , if you have one or go to HD.com and bring up a parts pic it may help
Old Feb 12, 2012 | 02:32 PM
t. sawyer's Avatar
t. sawyer
It can be a bear, If I remember right it was tough to hook the top in and also the instruction didtn 't seem clear about the visor and the ring mated. Stupid brain of mine. I' ll go look and see what I can remember.
Kroozeabout.
Old Feb 12, 2012 | 02:38 PM
Milehighturbo
This is the part # of the visor im putting on
Old Feb 12, 2012 | 02:50 PM
useR 564357348's Avatar
useR 564357348
Originally Posted by Milehighturbo
69733-05
It should fit according to my 2011 accessories catalog. How big is the gap? The reason I ask is the picture in the catalog shows a significant gap and one that I would question.
Old Feb 12, 2012 | 03:02 PM
t. sawyer's Avatar
t. sawyer
69733-05
Thats not the one I put on..sooo..I had trouble with the rubber ring gasket, so if it helps I can see the ring seal running over top of the visor. The other problem was hooking it in at the top far enought to make the bottom fit the way it should. I know I had to keep at it for awhile until I found the right combonation.
My visor is the winged logo one. so its not apples and apples.
I hope this helps alittle. let us know what the problem is when you find it, and I know you will.
Kroozeabout.
Old Feb 12, 2012 | 03:13 PM
mkguitar's Avatar
mkguitar
I had little trouble putting mine on.
as I tightened the screw, I worked the visor to take the contour properly.
just start at the top with each hand and work it toward the bottom so that it is not binding.
tighten a bit, do again
the gap closed up nicely
Mike
Old Feb 12, 2012 | 05:09 PM
iclick's Avatar
iclick
This has been a source of pain for many over the years, and the best fix I've found is to use a ratchet-bar clamp like this one.
The idea is that you need more to force the trim ring together than just the tightening action of the screw. So force it together first and let the clamp hold it in place while you tighten the screw. The plastic pads on the clamp won't harm the chrome on the ring, or at least it didn't on mine. Once tightened the ring will stay in place. It may not get rid of the gap completely but should get it close.
Old Feb 13, 2012 | 10:50 PM
cleanimages's Avatar
cleanimages
I thought i was the only one w this problem!!! Last week put on and took off 20x! Still a gap...
Old Feb 14, 2012 | 12:37 PM
casique's Avatar
casique
I threw mine away after bending it. It's a POS!
