Headlight visor
Old Feb 14, 2012 | 12:51 PM
hougz79's Avatar
hougz79
Mine had a little bit of a gap. Ask me if I care. It's barely noticeable.
Old Feb 14, 2012 | 02:35 PM
Hecklerboy's Avatar
Hecklerboy
Make sure it's pushed all the way over the stock trim ring.
I found it easier to take the stock trim ring off and slip the visor over it then install both together.
Old Feb 14, 2012 | 02:41 PM
Fatboy Brian's Avatar
Fatboy Brian
Originally Posted by iclick
This has been a source of pain for many over the years, and the best fix I've found is to use a ratchet-bar clamp like this one.
The idea is that you need more to force the trim ring together than just the tightening action of the screw. So force it together first and let the clamp hold it in place while you tighten the screw. The plastic pads on the clamp won't harm the chrome on the ring, or at least it didn't on mine. Once tightened the ring will stay in place. It may not get rid of the gap completely but should get it close.
That's the exact same thing I did. Makes it a whole lot easier.
Old Feb 14, 2012 | 04:22 PM
SamStone's Avatar
SamStone
Did you leave the stock ring in place?
Old Feb 14, 2012 | 04:38 PM
Keefersan's Avatar
Keefersan
This is how I got mine on too.
Old Feb 14, 2012 | 05:42 PM
LJROY's Avatar
LJROY
same thing here ...gap at the bottom and dont fit snug up to the stock ring around the whole thing. going to try some of your ideas or it will come off.
Old Feb 14, 2012 | 10:59 PM
olsenjb's Avatar
olsenjb
Had the same problem...there was no way to get it to close. I pulled the stock ring off and put it inside of the new ring just to check, and there was no way the new ring would close any further than about a 1/4-1/2" gap with it being installed over the stock ring.
So, here's what I did...
I removed the stock ring. I then removed the 8 or 9 screws that hold the headlight assembly to the nacelle. I put 1/4" flat washers on each of those 8-9 screws and screwed them back in. The 1/4" washers stick out just far enough that it gives something for the new trim ring to grip onto. Put the new trim ring on without the stock ring. Tightened it down...no gap and it looks great. Hope that helps....Seems like some of the new rings go on over the stock ring and fit perfectly, and others like mine will never fit no matter how much clamping and tightening you do.
Old Feb 15, 2012 | 09:27 AM
Hecklerboy's Avatar
Hecklerboy
I got mine on with no gap.
Even had to take it off a couple times and still got it back on with no gap.
You do have to leave the stock ring on and this ring fits over it.
Make sure you take the mounting screw out of the stock ring before you install the visor.
The stock ring has to be lose in order for the visor to slip over it and close properly.
After that just reinstall the stock ring screw and the visor bolt.
cbaywolf
Aug 18, 2015 08:17 PM
clackavosticus
Mar 31, 2015 07:34 AM
atlantaallen
Electrical/Lighting/Alarm
Jul 13, 2014 01:51 PM
gunner11
Feb 15, 2010 01:22 PM
06DEUCE
Apr 18, 2006 03:43 PM
