V thunder Hy-Rev Hydraulic Lifter input?
Old Feb 16, 2012 | 08:55 AM
TO34's Avatar
TO34
Default V thunder Hy-Rev Hydraulic Lifter input?
I have a stock 2000 Twincam 88 with the SE cam plate upgrade, everything else is stock that I have pulled apart at the moment. Going to replace the lifters nothing crazy just looking for reliablity.
"Hy-Rev™ Hydraulic Lifter: All of the lifters components are produced on state-of-the-art computer controlled machinery which holds the O.D. size, straightness and roundness tolerances to .0003", for the precise fit demanded of today’s high performance engines. Proudly made in the United States, each lifter must pass a stringent quality control test to ensure proper manufacture and function.
(1) Hy-Rev™ Anti Pump up Hydraulic Lifter, 1999-Present, Twin Cam BuellŽ 2000-pres., SporsterŽ 2000-pres., TC88"
http://www*********.compperformanceg...uct_Code=875-1
Old Feb 16, 2012 | 09:55 AM
djl's Avatar
djl
Nothing wrong with the CompCams VThunder lifters. I just purchased a set for a friend in Canada and CompCams confirmed that they were made by Delphi. However, I don't think you want the 875-1 lifters; they are travel limited. The 850-1 would be a better piece for you application. JMHO.
Old Feb 16, 2012 | 10:53 AM
DanDman's Avatar
DanDman
You will have to install adjustable pushrods.
Old Feb 16, 2012 | 01:22 PM
djl's Avatar
djl
Why? Adjustables are not necessary; he is just changing lifters. A little more work but the OEM pushrods can be pulled from the top.
Old Feb 16, 2012 | 01:41 PM
DTTJGlide's Avatar
DTTJGlide
I've had a set in my 103 with .570 lift cams for over 80K miles, still running great & can't beat the price.
Old Feb 16, 2012 | 02:00 PM
TO34's Avatar
TO34
Yup already have those (adjustable pushrods)
Old Feb 16, 2012 | 09:47 PM
DanDman's Avatar
DanDman
I have a set and you have to install adjustable pushrods.
dertyone22
Engine Mechanical Topics
Feb 17, 2022 08:29 AM
psoff
Aug 24, 2018 09:30 PM
Biker Bob
24
Aug 10, 2018 03:25 PM
Eyespy
Exhaust System Topics
26
May 10, 2016 08:12 PM
tombeving
Jun 25, 2013 06:56 PM
