Compression Testing....couple questions
Old Feb 20, 2012 | 10:43 AM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
Watch the length of any adapter you screw in that hole, too long and when the piston gets near TDC you can punch a hole right through it
Old Feb 20, 2012 | 10:53 AM
X Iron Butt's Avatar
X Iron Butt
Originally Posted by Expat1
Usually when you get that far you've already chosen to open the engine
Decarbing combustion chambers can fix leaking valves. Way easier than opening engine.
Old Feb 20, 2012 | 11:30 AM
djl's Avatar
djl
I agree with the previous comment on the length of the hose. Looking at the HF photo, it appears that you can unscrew the quick coupler from the hose and the hose from the union that screws into the guage. If you can, do it and screw the quick coupler directly to the guage for more accurate readings.
When you get that sorted out and are ready to take a reading, make sure the battery is fully charged, put it on a tender or charger to make sure the battery is fully charged before testing. Start her up and take the bike for a spin around the block to warm her up a bit and make sure the lifters are pumped up. Remove both plugs and ground them. Attach the guage, hold the trottle wide open and spin the engine with the starter; should take 5-7 cycles to pump up. Let the pressure off the gauge and take second reading to confirm the first.
Removing the fuel pump fuse won't hurt but not necessary.
johnod
EVO
Aug 7, 2018 09:17 AM
rockydog53
Jun 16, 2015 12:19 PM
rockajet1
Nov 26, 2012 06:10 PM
OneBlackFly
Nov 24, 2011 02:44 PM
hyPerhog
Exhaust System Topics
May 19, 2009 10:13 AM
