neutral switch
Old Feb 19, 2012 | 08:40 PM
hdnvn's Avatar
hdnvn
Default neutral switch
Well I replaced the neutral indicator light and then the neutral switch. Still no light on the dash when I hit neutral switch. Anyone have some insight as to what else would be part of the circuit? I have an 02 Electraglide Glide .
Old Feb 24, 2012 | 10:56 PM
sbyumabaker's Avatar
sbyumabaker
no impact no idea..... But I hope you checked voltage at your indicator... Good luck
Old Feb 24, 2012 | 11:06 PM
soft 02's Avatar
soft 02
Did you get the right nuetral sender. Some are normally open and some are normally closed and they look the same.
Old Feb 25, 2012 | 06:21 AM
shortride's Avatar
shortride
Check the indicator light to see if it's getting power. You may have lost the ground.
Old Feb 25, 2012 | 07:29 AM
WOLFMAN94's Avatar
WOLFMAN94
Ground issue, I went through the same thing. Found bad ground at indicator light.
Put in nuetral, the just grab a piece of wire and touch to a good ground and the neg side of bulb.
Dazzauk
EVO
May 9, 2016 02:36 PM
HDmikie
Jan 7, 2012 07:20 PM
skydrifter
Jan 22, 2010 03:42 PM
badgerland
Aug 6, 2008 08:36 PM
mradl2
Aug 6, 2006 02:19 AM
