PowerVision Question
Old Feb 20, 2012 | 04:19 PM
Rick Lees's Avatar
Rick Lees
Default PowerVision Question
I have a 2011 SG 103 and after downloading the tune to my scoot it seems to start hard...Jamie said to check the calibration and see if the ACR is on .....I emailed Jamie and I'm sure he's a bit busy so just wondering if checking it is as easy as plugging back into the bike and changing it there or do I have to do that on the computer change it there and reflash to the bike...... bike runs great just seems to hard start.
Old Feb 20, 2012 | 04:21 PM
mgmmgm's Avatar
mgmmgm
I do not have PV, but sounds like comp release issue.
Call FM they are good on support.
Old Feb 20, 2012 | 04:25 PM
57red's Avatar
57red
i have the same bike, I put rinehart classic duals, and FM ac, flashed mine with the PV and it started right up. I'm gonna do a data run and check all my settings after that, my bike is still running a little lean.
Old Feb 20, 2012 | 04:35 PM
Rick Lees's Avatar
Rick Lees
Don't get me wrong it runs fricking great just seems to start like it under high compression I got a email into FM and he answered my 1st question I just dot know how to check if the ACR is on.....Jamie will get back to me just wanted to know if it was easy to check myself. I loaded the tune and took it off for now....might be mounting it sooner the later
Old Feb 20, 2012 | 04:57 PM
jjnoble's Avatar
jjnoble
I thought I had power vision because I could see all that tiny fuzzy dust on all the signs, turns out I needed glasses.
Old Feb 20, 2012 | 05:05 PM
frog13's Avatar
frog13
I don't think you can change it on the bike, I think you have to do it in WinPV. Some stuff you can do on the bike, other stuff is on the PC. It is real easy....just hook the PV to teh computer, launch the program, load the file, go to Limits and Switches, then pick Active Compression. It should be set to 1 to be on, if not, change it and save the file. Then plug it into the bike and flash it.
Old Feb 20, 2012 | 05:10 PM
Teardrop's Avatar
Teardrop
You will need to download the WinPV software so you can open the map. Once you have the map open the ACR switch is under Limits and Switches and is called Active Compression Release. If the Value is set to zero it is turned off. All you need to do is set the value to 1, save the file, upload it to the PV and flash the new and improved map to your bike. Hope this helps.
Old Feb 20, 2012 | 05:33 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
I sent an email this afternoon with instructions on to make sure the comp releases are turned on, they are turned on in all of our 103" calibrations. As noted if you had your ignition switch turned on for an extended period I would make sure your battery is at a full charge
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Feb 20, 2012 | 05:42 PM
frog13's Avatar
frog13
Checking the battery IS a good option. I have a 2012 103" with PowerVision, cam, exhaust, air, etc. and had the comp releases off for a little while and she started as soon as you touched the button, nothing hard about it at all. I turned them back on to make sure I didn't wear the starter down.
Old Feb 20, 2012 | 09:34 PM
RADLINE's Avatar
RADLINE
I was going to say this is exactly what I would do.
I didnt see Jamies post before I responded so now I cant figure out how to delete my post...
Let us know what you find out about your hard starting issues...
