Horn problem
Old Feb 22, 2012 | 04:43 PM
Lgossett's Avatar
Lgossett
6th Gear
Default Horn problem
I have a 06 Flhtcui. Recently installed HD air horn. Worked well for about 2 weeks. Now I have no power to the horn. Checked wiring harness that I installed with fuse. Every thing seemed fine. Just wondering if there is a horn relay behind the faring that has gone bad. Everything from the battery to the horn seems ok. Even removed the tank just to see if wire was bad no luck. Need help.
Old Feb 22, 2012 | 05:36 PM
In2It's Avatar
In2It
Did you check voltage at the horn with a meter? There should only be 2 wires there power and ground.If you have power there then the horn took a dump.
Old Feb 22, 2012 | 05:42 PM
11rkc's Avatar
11rkc
i replaced 3 relays already with that same horn. put in a 40 amp one and has been fine for awhile now.relay on 11 rkc is under seat.
Old Feb 22, 2012 | 05:47 PM
Lgossett's Avatar
Lgossett
6th Gear
Checked voltage none at the horn. Believe it may be the relay. Anyone know where it is on my ultra?
Old Feb 22, 2012 | 05:50 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Did you install it? These air horns pull a lot of current...upwards to 18 or so amps. So a relay with contacts rated at least at 20 amps is needed, preferably use a 30 or 40 amp relay to have the design margin needed. Anyway, if this was installed without a relay, then you have damaged, probably burned out, the horn switch contact. That switch was not designed to handle more than about 10 amps. You have some troubleshooting to do with a VOM.
DamifIknow
Aug 3, 2022 10:41 PM
Red 62
Electrical/Lighting/Alarm
Aug 7, 2014 07:56 PM
numismaddict
Mar 24, 2012 06:09 PM
Ctac
Jan 12, 2010 09:47 AM
SportyPig
May 17, 2008 05:22 PM
