Do I need a PC
Old Feb 23, 2012 | 09:04 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
In one word, No. Slip 'em on, ride 'em for 'bout ten minutes or more and let the factory ECM do it's job. It does have the capability to make slight adjustments for no more than what you're doing.
Old Feb 24, 2012 | 07:44 AM
who?me?'s Avatar
who?me?
A factory reflash will still leave you with a 14.7 AFR. A tuner will be necessary to obtain a richer AFR and cooler running conditions.
Old Feb 24, 2012 | 09:07 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
an 06 will NOT COMPENSATE,no 02 sensors no closed loop mode.
Old Feb 24, 2012 | 03:55 PM
jjnoble's Avatar
jjnoble
I don't know about an 06 compensating, never thought about the 02 sensors. The Xieds use 02 sensors but I'm pretty sure they have Xied's for earlier model bikes. Give Steve at nightrider a call and ask him about the Xied's, then let us know.
http://www.nightrider.com/parts/
Old Feb 24, 2012 | 04:45 PM
Leftcoaster's Avatar
Leftcoaster
[QUOTE=EG-2006;9434738]Your 06 EG wont compensate for the addition of ac and slipons. 06 has no O2 sensors.
Bingo!!
XIED's won't help either, nor will a useless overpriced flash.
Get the PCIII, you'll never regret it.
Old Feb 24, 2012 | 04:48 PM
TUCCI's Avatar
TUCCI
Originally Posted by jjnoble
NO, you do not need a tuner. The ECM will compensate for an air filter and slipons. But it will compensate to the factory setting that it is now, which is lean and runs hot. You should check into nightrider Xied's, they will richen it up for you and only cost a little over one hundred dollars. But you don't have to, you can just do the stage one and leave it at that. If you decide you want more power or want it to run cooler then get Xied's or get a tuner if you want to be able to contol the mixture. Xieds work great though, if you are not into messing with the tuning then that is what you should get if you decide to change the fuel mixture.
+1 on the VIED, you shouldn't have to worry about a SERT or PC or any other acronym until it goes beyond a Stage 1.
sailnjay
"The Florida Crew"
13
Nov 3, 2011 10:20 PM
whodares
Jul 13, 2011 05:32 AM
Eagle51
Aug 3, 2010 10:18 PM
96inch
Exhaust System Topics
Mar 30, 2008 11:11 AM
rotorhead
Jun 1, 2007 08:41 PM
