well thanks to everyone who has shared some information on the subject, between the info here and my service manual i finally had the confidence to attack it.
anywho.. took me a few times to get it where i wanted it and i may have to do it one more time as the friction zone is almost too close now.
The reason why I'm posting this is my cable never really moved away from the lever itself. I hear a lot of people saying that they would tighten the clutch cable until there was a dime to a nickel's width between the ferrule and the perch. I feel good about my adjustment within the derby cover. But due to my cable never really backing out when slack, i dont know if i have the cable itself at the proper distance.
I believe they say a dime distance between the cable ferrel and housing when pulling on the cable! grab the cable and tug on it and measure your play from the housing.
If the ferrule is tight and doesn't move from the lever bracket, simply determine the amount of free play in the cable itself. The end result is the same either way. The number one criteria is simply to make sure you have some freeplay - More is better than not enough.
I always have to pull the clutch a little after loosening the adjuster to get the actual play in the lever. Then you can tighten up the adjuster until you can just tap the lever and have it jiggle. A good trick, like was said, is to stick a nickel in there (dime is a little thin for my taste) and tighten until it just barely stays.
If you don't have enough slack, you'll notice because your bike will creep with the clutch in.
... If you don't have enough slack, you'll notice because your bike will creep with the clutch in.
You've got that backwards.
Not enough "slack" (or I call it freeplay) will not cause the bike to creep with the clutch in. Creeping would be caused by the clutch not disengaging completely and that in turn would be caused by too much freeplay.
On the other hand, what could happen if you do not have enough freeplay is the clutch may never fully engage, and then you'll have slippage when placed under load.
This is the reason why I stated in an earlier post that more freeplay is better than not enough freeplay. Not enough freeplay can cause accelerated wear of your clutch, while too much freeplay will not cause any damage, but may cause "creeping" as you say and harder shifting, especially finding nuetral.
You're correct. It's been a long week...
Not enough freeplay would mean slipping clutch, too much and you'll never disengage, just like you state.
