Noob here. Just bought a 2007 Road King FLHR in need of a new gas tank. I have a line on a tank that is off a 2007 Road King FLHRC Classic.
Does anyone know if this tank will fit?
And what are the differences in the two models?
Thanks in advance.
Generally the differences are only features - hard bags and cast wheels on the standard, leather and spokes on the classic. Not sure about 07, but in 2012 the other differences are that ABS and Cruise are standard on the classic but not on the FLHR
Not 100% positive, but I think about the only difference between the 2 is the bags. Leather hard bags for the classic and regular hard bags for the standard.
As far as the gas take goes, I believe the FLHRC has a cast 3D emblem that's glued on the tank where the FLHR has the painted 'emblem' on the tank. For the tank, that should be the only difference.
Oh, but yes . . . the "C" has leather, blah, blah, blah . . . not sure what leather 'stuff' has to do with a gas tank. If it matters at all, and you use the tank, folks will know it's a C on a non-C. But it's a hellofa lot cheaper than a new one I'm sure!
So I found a website that allows a part look up free. You just have to add the part to your shopping cart and then view the cart. Part number is listed there. I compared the tank from FLHR and FLHRC same part#. http://partsfinder.onlinemicrofiche.....asp?make=hdmc
thanks for the tip on Ronnies. Part numbers for the 2007 FLHR/FLHRC are the same 61268-03. What happens for 2009-2012 FLHR 61268-XX and FLHRC 61500-XX? Numbers are different but the tanks look the same-anyone try this swap?
BTW one difference in rear fenders is that the FLHRC fender is drilled for the standup license plate.
