Help! Outer primary cover
Old Mar 7, 2012 | 08:18 AM
Eric Moore's Avatar
Eric Moore
I would use caution on prying aging the sealing surface.. or sticking a blade inbetween both halves.. it may gouge the surface if it leaves a deep enough scratch it may leak of you may have to use sealer to fill the void..
Old Mar 7, 2012 | 07:55 PM
HTNHARD's Avatar
HTNHARD
Yeayaa!! Got the cover off. Compensator installed. Made a wedge at work out of some stainless. Ground the end to a knife edge. Carefully worked it in from the top middle. Can't believe it worked. Thank you to all who helped. Much appreciated!
Old Mar 7, 2012 | 07:57 PM
1flhtk4me's Avatar
1flhtk4me
Now you can sell them here!
Old Mar 7, 2012 | 08:50 PM
Loc_Tite's Avatar
Loc_Tite
That compensator looks nice in there, glad to see you got it!
Old Mar 7, 2012 | 09:08 PM
Thatzmister2u's Avatar
Thatzmister2u
I vote for one of those GPS or phone mounts for your windshield. Lock that suction cup on an yank away!
Old Mar 8, 2012 | 04:46 AM
DOMAPOI's Avatar
DOMAPOI
Congratulation on your success!!!!
Old Mar 8, 2012 | 05:40 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Yeayaa!! Got the cover off...
Before reassembling, make sure the comp bolt is torqued and the tensioner is adjusted up correctly with little to no slack in the chain.
Then make double sure the primary housing is very clean and free from any particles that might prevent a good primary cover seal.
Add fluid, button it up, and then ride!
Well done and good luck!
jacknthebox
Aug 24, 2013 05:19 PM
Joe What
May 23, 2012 05:34 PM
mikeburgess
Aug 26, 2009 12:54 AM
kelton3
May 1, 2008 03:36 PM
carguy9497
Oct 7, 2006 11:45 PM
