Grease fitting on frame neck
Old Mar 13, 2012 | 08:35 PM
tom lipke's Avatar
tom lipke
Default Grease fitting on frame neck
I have an 01 electra glide. It has a grease fitting on the neck. what kind of grease and what is the required amount to fill? only 10k mi on the bike but I don't know if it has been serviced or if at that low mileage even calls for it?
thanks
Old Mar 13, 2012 | 08:49 PM
goose136's Avatar
goose136
i also have 01 manual says service every 5000 miles using special purpuse grease part #99857-97 don.t know if you can just use mult-purpose grease.
Old Mar 13, 2012 | 08:56 PM
Crash75's Avatar
Crash75
I would fill the neck with grease till it pisses out of bearing races. Then clean up excess. As far as I know, Harley does not fill the neck so if it has not been filled before, it will take quite a bit till it is filled. Just keep pumping it in. That is what I had to do.
Old Mar 13, 2012 | 08:59 PM
davidsdad's Avatar
davidsdad
Some people complain the grease continually runs out during the summer months from filling it with so much grease.
Old Mar 14, 2012 | 07:16 AM
1flhtk4me's Avatar
1flhtk4me
Just wipe off the excess from the bottom.
I use wheel bearing grease.
Old Mar 14, 2012 | 07:59 AM
katobird's Avatar
katobird
any multi purpose grease, just get one that isn't real oily..
or it drips for a long time.
I never had a problem using standard GP from auto zone
Old Mar 14, 2012 | 08:12 AM
shortride's Avatar
shortride
This bring to mind a question about replacement bearings. Are there any sealed replacement bearing for this application?
Old Mar 14, 2012 | 08:22 AM
Talldog's Avatar
Talldog
Pump it in til it comes out the Races, but make sure to use good quality Synthetic Grease or you'll end up with a mess on a hot day.
I use Royal Purple Grease and no problems so far.
Old Mar 14, 2012 | 08:39 AM
petewerner's Avatar
petewerner
thanks
I use lithium based grease as I ride in rain and use a pressure washer to clean the heavy crap off my bike regularly. It works fine as I have no problems and never have. What Crash75 said is what alot of us do around here in Boise. It will take anywhere from 30ish to 60 or more pumps with my full sized tube grease gun to fill the few I have done or seen done.
Yesterday 09:56 PMCrash75I would fill the neck with grease till it pisses out of bearing races. Then clean up excess. As far as I know, Harley does not fill the neck so if it has not been filled before, it will take quite a bit till it is filled. Just keep pumping it in. That is what I had to do.
Old Mar 14, 2012 | 08:51 AM
mrfikser's Avatar
mrfikser
I use lucas red and tacky #2 ....it doesn't drip like the stuff harley puts in there and lubes just fine....it takes almost a full tube the first time you grease it...
