MPG Help
My fuel mileage dropped to 30 mpg. At times it dropped to as low as 27 mph.
Riding 4K miles in this condition, I complained to anyone that would lend me an ear. I got this one recommendation over and over again, both locally and on line. Go see Doc Weaver or at least give him a call up there in Minneola FL. I'm told.
I did, made an appointment and off I went, 140 miles up the turnpike. First thing done was getting rid of the SERT tuner when Doc got it. He installed a TT Master Tuner. Then he spent 2.5 hrs on the fuel map on his dyno. After about 4.5 hrs he was done. Doc got me another 10 HP & 10 TQ over my dealer's dyno tune. Now I'm showing 110 HP 120 TQ at the rear wheel. He also got rid of my throttle hesitation that I wasn't aware I had till he got rid of it.
Now the News you've been waiting for. I'm averaging 40 mpg now, riding the same way when I was getting only 30 mpg average.
You my friend need the best reputable tuner you can find in your area. Even if it means riding several hundred miles to get to him. Ask, research and listen to those that are VERY satisfied with their dyno tune. Then call the tuner and decide if he's the one for the job.
Even though this dyno cost me another $850 with the tuner. It'll pay for its self after 21K miles at present fuel prices.
Ride safe...
I purchased heated gear before the winter started so this is the first year I have put a decent amount of miles on my bike during the winter. I too noticed that my MPGs dropped from around forty to thirty one. I have an '07 Road King Classic with a Thundermax and Rhinehart True Duals. I thought I might have a problem with the Thrundermax. While i was in Daytona, I stopped by and saw them. They hooked up my bike and said that everything was fine. Zippers Performance, the manufacturer of Thundermax, is also from the MD / DC / VA area. They told me that that this kind of drop off in MPGs during the winter in our area is typical because of the amount of ethanol in the gas. I thought they were just brushing me off so my buddy, who was also having the same problem, and I put this theory to the test by filling up with 93 octane while in Daytona. Sure enough, I got just over forty miles per gallon. When we got back home and filled up again, I was back down to about thirty one miles per gallon. I was told that sometime in the Spring is when they remove the ethanol from the gas and that I should, once again, see increased mileage. I hope this helps.
If you don't mind, send me your dyno map and the tweaked map FM sent you (here). Assuming FM adjusted your dyno map and didn't replace it with one of theirs, I'm not sure how they made the adjustments without any knowledge of how the tuner set your AFRs for the cruise range. If they didn't replace it they may have compared it with an in-house map for your configuration and adjusted accordingly.
I would go to the person who performed the tune and ask them what AFR was used to tune the cruise range. I would also ask if there is some way they could make an adjustment to improve the mileage, and I would specify an AFR of no richer than 14.2 in the cruise range. I'm using 14.5-14.6 and have no heat issues, but most don't like going that lean, which is right at stock levels. FM tunes for 13.8 in their regular maps, which is too rich for my taste but good for improved cooling and throttle response. Remember that most riders complain about heat, and this tuning strategy is in response to the demands from owners.
Adding Auto-Tune would be another option, as then you could specify AFRs throughout the operating range and there would be no guesswork. I usually don't recommend AT for most riders, but in your case it may be the only way unless you can get the tuner to tweak your map.
Anyway...
My best riding buddy had a 2011 FLHX with the 103. He has SE intake, SE slips (cat in), 255 cams, and some kind of SE tuner. It was dyno tuned by the dealer. We ride thousands of miles together. Same roads, same speeds, same hijinks, etc. He averages 5 MPG better than me.
I know he has 6th gear, but still... how does that 103 with cams do so much better than my little 88??? Only thing I can come up with is my FM map is letting those injectors squirt plenty of fuel.
Would like to get better mileage when touring, but like the throttle response when tearing up the twisties.
motorcycleoil-site.com/1526120 has specs on this. Synthetics also help your bike run cooler.
Thanks.
