MPG Help
I'm surprised you are seeing values like -16 and would like to look at your map(s) if you'll email me what you have.
Also, I wouldn't change any value above about 80% TP or 3000 rpm, as you want to keep the power that is part of the map you have installed available when you need it. If you spend most of your time in the cruise range like most of us you should see a mileage improvement by altering only the cruise range. In my maps I usually tapered the values at 40-60% TP so the transition isn't so radical, though, but that's optional. Unless you do that you may feel a four-barrel-carb effect when you roll-on the throttle and get into the richer part of the map. Tapering the values may smooth it a bit.
Great questions and excellent answers and explanations. I am sure once I get the PCV and software this will all make more sense.
This thread will give me something to refer back to if I start have mpg issues.
Thanks all.
2002 Deuce averaged 50.6 (TC88b) Stage 1, V&H Big Shots. Don't anticipate being anywhere near that but somewhere in the 40's would be nice.
Thanks for all of your info iclick!
