What gives??????
Old Mar 16, 2012 | 08:43 AM
Mr. Mike's Avatar
Mr. Mike
also check that your enrichener **** (I think your carburetted) that it's functioning properly.
Old Mar 16, 2012 | 08:50 AM
PktChg's Avatar
PktChg
If you are referring to the choke, it seems to be working fine. But......how do I check to make sure it is working properly?? When I pull it to crank in the morning, it revs a bit more and when I push it in, it drops idle. Other than that, I have no clue if it is working properly.
Old Mar 16, 2012 | 08:06 PM
Mr. Mike's Avatar
Mr. Mike
Default enrichener ****
Pk,
More than likely it is functioning correctly based on your description. Normal, warmed idle should be somewhere near 950-1000 rpm. Fouled plugs would be an indicator too, so be sure to check out the condition of them, but it sounds as if your replacing them for good measure anyway. Hope it turns out to be a simple fix for ya.
Old Mar 17, 2012 | 06:27 AM
PktChg's Avatar
PktChg
Called the local dealership and found out the plugs should be gapped at 40,000. I pulled the plugs and they look ok, but were gapper at 30,000. Plus they were shitty Champions. I regapped and will run a tank through. I'm gonna replace the plugs with stock, I just want to see any improvement.
Old Mar 17, 2012 | 08:17 AM
AlanStansbery's Avatar
AlanStansbery
My first guess is there was something faulty with your measurement for the 100-mile tank. What was your next tank MPG like? I don't think plugs would have such a dramatic effect on MPG.
Alan
svfiat
Milwaukee Eight (M8)
Jul 17, 2017 07:48 PM
tperk
May 19, 2016 11:14 PM
gslobo
Mar 4, 2015 07:05 AM
jyd83
Mar 11, 2012 11:15 PM
Giddy_up
Engine Mechanical Topics
Dec 8, 2008 09:55 AM
